Anyone Weighed a 2020 2500HD?
Just wondering what the actual weight of a 2020 2500HD Crew Cab is. Mine is an LTZ CC with 4WD that Chevrolet says weights about 7500 lbs. I keep seeing reviews where the weight is stated to be 8000 lbs in the review. I'm guessing that GM's weight is dry weight without fluids and fuel. Show your actual scale weight if you've had it weighed.
The weight of our 2020 2500HD Duramax Denali, with full fuel and DEF, plus my wife and I in the vehicle was 8,620 lbs. on a CAT Scale.  Leaving us with 2,730 lbs. available payload capacity (11,350 GVWR - CAT Scale weight).
Curb weight is the weight of the vehicle with all options and full of fuel and liquids.  Take your GVWR and subtract your Cargo Capacity from the Tire and Loading sticker and that's how much your truck weighed at delivery.
I’m guessing yours is a 6.6 gas motor. Diesel versions are heavier.
Well, that's considerably heavier than my prior truck, an 08 that weighed just over 7,000 lbs.  New truck is a diesel, I should have said so.  That's exactly what I wanted to know.  Thanks all!
The silver towing label in the driver's door jamb (its on the lower part of the B pillar) has the published as optioned curb weight of the truck.  Take a look at it, that is the correct curb weight based on the build of the truck.
Found it and the weight is clearly labeled on that decal.  8,175 lbs - well over the 7,005 lbs scale weight of my 2008. It's a devil to get a picture of though.
Muchas gracias senore!
Yeah it's interesting to see how much heavier these new trucks are.  My 2009 Duramax CC dually weighs 8,000lbs with my normal load out.  These new 2500HD with the shorty bed are weighing in empty as much as my fatty.
    ar0517
    ar0517
  • Who's Online   4 Members, 0 Anonymous, 529 Guests (See full list)
