I wanted to show you guys the back and inside of the trim of the fog lights incase anyone is wanting to removed them for whatever reason. Im taking mine off because im having them painted (Still undecided on what color). I tried a matte black wrap to see what they would look like for now.  You want to start from the bottom with a long flat head screw driver and be very gently prying so you dont mess up the paint on your bumper. Take your time and work your way around and it will pop off. The black inser for the fog light comes off as one piece with the trim. You can remove it off the trim once the trim has been removed.
WuJzdP.jpg[/IMG]0Y8BWk.jpgrTfK3R.jpg[/IMG]
aO7Bhh.jpg[/IMG]
QENsm0.jpg[/IMG]
rQ3s1K.jpg[/IMG]
HMppjX.jpg[/IMG]
0NUjw9.jpg[/IMG]
JbU2R5.jpg[/IMG]
Edited by amog4life
  • Thanks 2
Was thinking of having mine painted on my AT4 as well.  Keep us posted - would love to see more pics.
1 hour ago, amog4life said:
I wanted to show you guys the back and inside of the trim of the fog lights incase anyone is wanting to removed them for whatever reason. Im taking mine off because im having them painted (Still undecided on what color). You want to start from the bottom with a long flat head screw driver and be very gently prying so you dont mess up the paint on your bumper. Take your time and work your way around and it will pop off. The black inser for the fog light comes off as one piece with the trim. You can remove it off the trim once the trim has been removed.
Welcome to the site.
I personally think that you deserve an award for being brave enough to rip apart your new truck!!!
That is one of the best parts about this forum, is the courage to pull/rip/modify these new (expensive as hell) trucks apart  to see how they were built, and then make them your own "day two" truck!
Says a lot about the people in the GM family, the pride in ownership is alive and doing well, as long as we survive the Covid-19 crap.....
Was able to post new pictures a different way.
Hahaha well thanks man.
Ive been around cars my whole life so i love to get in there and see how stuff is made and be able to modify it. I will be taking out the Denali grill here soon as well and might make a video on it or take a lot of pictures as well. All these parts may be getting coated gloss black. Im actually new to the GMC world. I was always more of an import kind of guy and i was really struggling on getting a 2020 Tundra or the 2020 GMC. But the look of the GMC was just amazing and the Tech on them leaves the Tundra in the dust. So i went with the GMC Denali. Ill be posting more stuff as i start to take it apart.
You are very welcome.
Congratulations on your new truck!
  • 4 months later...
I can't remove these....like won't let go lol.
Its not easy, you need to be lucky to get them.
Correct way is to remove the headlights and pinch the tabs or something along those lines. Too hard to access from below.
Sent from my SM-N975W using Tapatalk
Yeah I was wondering....buddy seemed like it was extremely easy and you pry and they pop off lol...Ive tried and yanked on them...
You need to be careful to pry on the bezel and not the truck front end.
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
