8" instrument cluster
Has anyone gone from te 4" to the 8". I have an AT4 and would like to do the swap. Wondering if its just the cluster or what.
Sent from my SM-G973U1 using Tapatalk
Nope no tech package, I'll just check pick n pulls if its plug and play, I wouldn't see why it would be anything more involved
There was a discussion on it somewhere in here of someone doing it on an RST
It’s just the speedometer that needs to be swapped but it first needs to be reprogrammed to work for your vehicle
I might have a Denali Cluster up for sale soon if anybody interested in it
Let me know Josh. I want to upgrade my Silverado Custom.
FYI the Denali cluster has the GMC logo on the trim.
Here is a current thread about the swap:
Thanks for the heads up
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
