Service Airbag Message
I am brand new to this site and forums in general so please forgive me if I misstep...
Today, I removed all of the seats and center console from my 2016 Silverado to replace the floor vinyl.  I started by disconnecting the battery of course.  After I reinstalled the seats and started the truck, I got the Service Airbag message and also the Traction Control icon ( I thought that was a wierd combo). I checked to make sure all of the electrical connections were secure and they were.  I did remove the two electrical connectors from the airbag control module under the center console but didn't remove the module itself.
As I said, all electrical connections are securely seated... any ideas what I did wrong?
Thanks in advance!
Did you reconnect the harnesses to those modules under the console?
Anybody have any ideas? I discovered today that my son DID remove the module from the mounting studs "to look at it"... if the module was turned upside down, would it think there was a crash and need to be reset/replaced? I;m not sure if it was or not, but I am out of ideas here.  ANY suggestions would be greatly appreciated.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
