The truck is finished :)
For at least 7 years, I wanted to upgrade the front of my truck and never got around to it.
I was involved in an accident last month and since most of the front end parts needed to be replaced, I thought now was the time.
I didn't like the white end caps on the front bumper, they stuck out like a sore thumb. They don't seem to flow with the look of the truck.
The chrome grill and bumper was the way the truck was new, and now I have it completed with the white LTZ grille and white front end with chrome tow hooks.
So what do you think?
Oh yeah!
Looks great!
Well done [emoji482]
I agree, that's an improvement; the white looks nice.
Do you happen to have an exploded view of the bumper, supports and other parts, showing how they're all mounted up?  My wife backed into my truck and the bumper is bent and one of the corner trim pieces is sitting ******-eyed.  I have been contemplating taking it off and trying to adjust the corner piece and replace the bumper, but would like to see how it all bolts together before I do all that.  Thanks!
I happen to be very lucky to be in this situation, because the insurance wanted to pay to repair the vehicle the way it was using aftermarket and used parts.
I do bookkeeping for the body shop and told the owner I wanted to upgrade the looks of the truck and he let me order all the parts from the local Chevy dealer. That way, I got no aftermarket parts and we stayed within the estimate so it didn't cost me anything.
After getting the estimate from the insurance co, I used https://www.gmpartsdirect.com/
to look up parts and part numbers to be sure to order the correct ones.
The parts views sometimes are misleading if you are not familiar with the way the truck goes together, like I was, and had to send back and reorder parts a couple of times. Luckily the dealer will accept returns from the body shops they do business with all the time, I am not so sure if they would take returns on special order parts for retail customers. The trick there would be to tell them what you need, let them order the part and if it is wrong, then they ordered the wrong part. If you go in and order a part by part number, you are usually stuck with it, because you told them what to order.
Of course the dealer wants to go by the VIN number and they were helpful in getting the correct parts for me, even the ones that were not originally on the truck when new.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
