2002 Silverado 2500HD 6.6 335,000 Miles
When I come to a stop and then release the brake pad there is a significant bump.  U-Joints are good.  Anyone have an idea as to what is causing this problem? Sure would like some input.
When this happened on my 2002 1500 it was the slip yoke.  The dealer replaced it with a nickel coated slip yoke and all has been good since.  This was at 15k miles and now has 197k.
As stated, more than likely the slip yoke sticking then releasing. You can also lubricate the splines
Heh.  Remember back in the day on here when this was the most common complaint?
Your 1500 is much different than my 2500HD 4 wheel drive.  But thanks anyway.
You've still got a yoke with splines at the trans, that's where the stick/slip can occur. At least look into it...... since I had a 4wd that had the issue.
It's been described by some as if they were bumped from behind by another vehicle
If it's not the issue then move on to other things.
I had a 03 1500HD that started doing the rear bang at around 215000.  I ended up selling it before I definitely fixed the source of the clunk, but in the process of trying to figure it out, I came to believe it was in the leaf springs—not the yoke.  There is a post either on this forum or the silveradosierra in which a guy bought some $30 u-bolts from local auto store and placed them just beyond the factory ubolts on the leafs.  It fixed his thudding, and others there commented it worked for them too.  IIRC, his bottom leaf spring was slightly askew of the top two, but they straightened out with the additional u-bolt.  My 03’s springs were like that too, which is why I believe that had I added the extra u-bolts, mine clunk would have been gone too.  For $30, what have you got to lose?  I will try to find that other forum thread for you.
Here is the link to other forum’s (gmfullsize) post on this.  Topic started as question about yoke clunk but included excellent info on leaf spring clunk fix.  See in particular post 35 in that thread, which shows great pics of that guy’s issue that you could compare yours too, but there are other posts in that thread discussing as well.
https://www.gmfullsize.com/threads/gm-yoke-clunk.239570/
Good luck,
Mark
Mpls, MN
Thanks that is the first thing I will ask my mechanic to check.
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
