After the recent recall for Emission System upgrade to comply with gov standards (done 2 weeks ago) the base idle speed has increased to over 800rpm. Used to be just above 500rpm. Dealer says the higher base idle speed is "with limits". I don't agree. Talked to 2 drivers of similar trucks today and both said there base idle speed is just above 500rpm. These are company trucks so they don't know if recall upgrade was performed on the trucks they are driving. The exact scenario is that when I start the engine, idle is normal at just over 500rpm. It stays normal when shifting into DRIVE. Then start driving and at the very first stop 700m from my house, it base idle is over 800rpm. It stays like that until I shut down the engine and it is back to 500rpm when I start the engine again after work. But only until the first stop when it stays above 800rpm. This has been going on for the past 2 weeks (during which I also did a 1200km highway trip). I cannot find a reference to base idle speed on this engine. Is 800rpm considered normal? If it is my "new normal" I'll be selling the truck as it is driving my crazy with the added noise sounding like a jet engine at startup.
Edited by jaws3
spelling
Go to a different dealer.
Example:
We had oil pressure gauge on lml suddenly read 120 psi anytime above idle.
GMC dealer said there was no max spec for oil pressure just minimum. I suggested they change sending unit as everything was fine the first few years. They politely offered me an oil change I’d have to pay for
I complained to GM customer care and setup an appointment with Chevy dealer across town. They replaced sending unit and all was back to normal.
Original dealer must have gotten a call from GM because they called me and offered a free oil change as an apology.
Good idea but not easy. Next dealer is 200km away from here...
Aftermarket floor mats?
Position sensor for skinny pedal loose or out of adjustment?
I'm not buying dealers 800 rpm soy either.
On the diesel sites lots have reported having the recall done -- no one has reported an increase in idle speed.
Edited by redwngr
No aftermarket floormats. Everything as it was prior to the recall except the 800rpm. But thanks for corroborating that it is not normal.
Good point ho
7 hours ago, hollywoodsle said:
Good point.
They can run high idle at startup, sorta like automatic choke on an old gasser.
And they can run higher for a reason like electical load, coolant temp and so on.
They also will run higher shift points when cold.
My response was interpreting the op's description as never returning to a low idle once fully warmed to normal.
It will also run higher idle when Regen is active iirc on mine it is right around 800-900 rpm .  Make sure it completed a Regen.
Yes, idle never returns to baseline. This is not a "variable" idle rpm. It is over 800rpm all the time. Except at start up when it will idle at nase rpm  ut as soon as I drive off and stop the first time, it is above 800rpm and does not ho down until I shut down the engine
Edited by jaws3
Clarification
6 hours ago, white94rx said:
Your truck is in the middle of a regen. Drive it longer and when it's done the idle will go back to normal.
Sent from my Pixel XL using Tapatalk
Thank you white94. In my original post I stated this has been going  on for 2 weeks since the software update. It includes daily driving as well as a 1200km weekend trip. Surely that should be far enough? I have also noticed over the past 3 days TV that the gear change occuring just above 50km/h is very rough. As if the truck "jumps" at that changeover. Not sure if it is related but the truck is rapidly becoming very unpleasant to drive. Will make another call to dealer as that seems to be my only ootion. Apart from selling it.
On 4/25/2020 at 11:31 AM, white94rx said:
That definitely should have been far enough. Mine usually takes about 20-30 minutes.
Mine does it in exactly 20 miles if kept above 40 mph
1 hour ago, curver900 said:
A call to gm customer service is probably in order or have another dealer or this dealer reflash it
Have an appointment with the dealer next week to look at this again
    • I am experiecing the same issue, I have gone in the setting and disabled rain sensing function but I am still experiencing this. Whe i use my turn signal they will redomly turn on. Sometime they stay on and others times we swipe 2 or 3 times and stop. Its super anoying, escpecially after a fresh wash. Anyone have any advice? . rain-sensing function, but I am still experiencing this issue Sometimes they stay on, and other times we swipe 2 or 3 times and stop.It's super annoying, especially after a fresh wash.When I use my turn signal, they will randomly turn on. I am experiencing the same issue. I have gone into the settings and disabled the rain sensing function, but I am still experiencing this.
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
    • If we're talking futures, yes, it's speculation.   The spot price of a delivered barrel is elevated now compared to before the conflict. And that is related more to current supply/demand.
    • SPECULATION on the wars effect raised prices. AI is maximizing the profit. Refining is vertically integrated.
