60227905534__2BDAC3CA-A915-49A4-A1BE-19EA3A16C635.thumb.JPG.f07463905d29ee1be3564f44900b152e.JPGThose GMC AT4's are awesome trucks may need to trade my silverado for one!!!
Edited by x GMFAN x
I went back and forth from GMC to Chevy and I just didnt like the front end on the GMC Too big and the front wheel openings , so I went with the Chevy, but there both nice.
https://www.readylift.com/2-25-front-leveling-kit-w-control-arms-at4-trail-bossgm-1500-truck-2019.html
I was thinking of the Readylift 1.75 but i'm not 100% sure i want to trust it. the AT4 is basically a regular seirra with a 2" already added so adding another leveling kit just seems like a way to prematurely wear our the suspension or CV's
BDS 2.5" is actually a 4" lift and eventually thats probably what i'll end up doing.
Do you have a link for the BDS 2.5”? All I see on the website is a 4” coilover system.
I was afraid that was the one you were talking about. $4k x_x
It's the coilover version so that pretty much doubles the cost
Sent from my SM-N975W using Tapatalk
Nope, no one has ever put one on, want to be the first? Just to be sure let me search and see but I am thinking not.
 Just a few found when searching. Chances are if you are thinking it then it has been asked already and the answer is out there...
Tyler
Just
They have two options at half the cost with alternate shocks - the mid package with the Fox 2.0, not piggyback shock is a nice middle ground.
I did Ready Lift SST kit - did not pay attention to their note you are "not recommended to use 4WD auto"  I paid more attention to it after talking to someone who toasted the front diff, due to shifting into auto 4WD on the fly - no warranty coverage - so if you are going to use your truck "offroad" or want the benefit of auto 4WD - then you need to go with a kit that lowers the diff to protect the factory geometry.
Had I done more homework I would have gone with BDS right away to fully address the problem - plus you get some added skid plates and stronger overall connections - so the kit improves your truck on every aspect - where the "level" kits simply level your truck and may compromise your truck long term for wear on CV axels.  You get what you pay for here.
Here are the base BDS options - that are not $4k and a you tube video showing differnt shock options.  $2K with Fox 2.0 - $1.8K with NX shocks (similar to Rancho).
BDS with Fox 2.0 front shocks ($2k):  https://bds-suspension.com/product?ma=5&mo=1&ty=113&yr=2019-2020&kid=749H
Shock Options BDS:
Edited by Supercup
Here is my truck - leveled with Ready LIft SST kit, when it first when on (bottom pic and the after I added wheels - stayed with stock tires for now.  SST kit comes with 0.5" taller block for rear to made it fully level.
Methods.thumb.JPG.9d0460c90210bba9f56bc59e1eadaeb5.JPG1774283387_LeveledTruck.thumb.jpg.b8535f0f8e583d235494bdb8729f1b63.jpg
Edited by Supercup
Shock Options BDS:
Thanks for the pics. I have a 2021 1500 AT4 and just had the SST 2 inch kit installed. I love the look of the kit and rides ok. I say ok because the ride isn't as smooth as before. More bumpier than before the kit. Everything else is OEM and I'm wondering if it is worth the 2 inches now. I plan to put Nitto 33's with 22x10 (-18) 4 Play wheels on it and need it to fit the 33's. Just seeing who else have had the same issue.
@SupercupThanks for the pics. I have a 2021 1500 AT4 and just had the SST 2 inch kit installed. I love the look of the kit and rides ok. I say ok because the ride isn't as smooth as before. More bumpier than before the kit. Everything else is OEM and I'm wondering if it is worth the 2 inches now. I plan to put Nitto 33's with 22x10 (-18) 4 Play wheels on it and need it to fit the 33's. Just seeing who else have had the same issue.
    DroppingDiesel
    DroppingDiesel
  • Who's Online   4 Members, 0 Anonymous, 903 Guests (See full list)
