Hey looking to put 35"s on a 2020 trail boss... Local shop said I would need new rims and a 6" lift kit...???? If so is there anything I need to know about what type/ kind of lift to go with to avoid future issues..looking for some product recommendations.. don't care for the way these trucks sit stock, tires seem small????
I would probably do more research on here first before deciding. There are many people on here who have 35" tires with just leveling kits or slightly higher. Your trail boss also has larger wheel openings to easily allow larger tires compared to my AT4.
1 hour ago, whoisRowdy said:
2020 TB w/ 1.5” level kit only
17x9 icon wheels & 35” BFG KM3
 No rubbing
You fit 17's on this truck?! Hallelujah! I've been searching far and wide to find a 17" wheel that fit these trucks. I didn't think I was going to be able to! Any specific backspacing to look for? Did you do any trimming?
While we're at it- Any power loss/MPG loss with the bigger/heavier tires? Do you have the 10 speed trans or 8 speed?
Great looking rig. I've got the same one!
Ya brother they fit no problem.  They are the icon compression wheels.. I just looked them up and they are actually 17x8.5 0 offset 4.75 backspace.  I did have to trim the mud flap a little and remove the flap bracket.. I used one of the bracket bolts to pin back the fender liner and it doesn’t rub lock to lock.. was happy how it came out with very minimal mods to make it fit..
as far as power I’m not sure the difference as I put the wheels on a few weeks into buying it.. although I’m positive I lost some MPGs and some pickup.. regearing is an option but it’s not really noticeable and I’m not racing the truck around anyways..
I was actually thinking down the line if I do long travel and fenders, I’d go to 37s and def regear.. but that’s more a dream than a reality..
11 minutes ago, whoisRowdy said:
The icon site has a photo of a T1 with these wheels so that’s how I knew they’d fit..
https://www.iconvehicledynamics.com/wheel/11912/icon-alloys-compression/2017858347SB/?finishID=1902
Awesome, thanks for the feedback!
Yeah that looks perfect..exactly what I'm looking for " more tire " I appreciate you getting at me with a picture...oh just wondering does the trim PKG matter , rst, lt, custom ?? I've got the custom...truck came with some decent black alloy wheels 18 x 8.5 ya think Maybe I can use them with the 1.5" Lev & the 35" Bfg's ?? Seems every local shop around here (L.A. CA) just wants to push a $6500 lift  rims and tires.. crazy
I like more tire too. 17x8 methods 0mm no spacers.
Great looking truck!
23 hours ago, Guy Denuccio said:
Truck looks great, do you have a leveling kit or small lift on that ?? Do you have any rubbing issues??
I have the Eibach pro truck struts and springs in the front. I have them set on the third strut perch. The rear is the TB blocks that came on the truck and the Eibach struts. I’m around 3 inches in the front and 2.5 in the rear.
I trimmed the mud flaps and removed the bracket, no zip ties though. I don’t have rubbing even on flex in the front but I’ve trimmed all the places I was rubbing before so you have to be willing to slice the liner a bit.
I have a 2020 Custom 4x4 (Not a trail boss). I added a 2.25 procomp level up front and was able to fit 35x12.5s on my stock 20’s. I did delete the flaps/air guards, but have no rubbing even at Full lock.
I had two different (reputable) 4x4 shops say something similar to me about needing a 6” lift to get to 35s. Guess it’s in their best interest to have you spend $2500 getting a Massive kit installed and selling you a tire package for another $2500. Also to be fair to them, ( at least the ones around here) they aren’t very familiar with the T1s yet
I have the tires and stance I want and am all-in for less than $1400
Truck looks great... That's pretty much what I'm looking for,,," better stance and more tire" thanks for sharing.
    • I never understood the hate for the column shifter. The console shifter just gets in the way, takes up prime cargo space and in my wife's Jeep, the dog constantly bumps the console shifter into neutral!    Best choice ever to just make it a column shifter across the lineup and be done with it.    (Bonus: Makes swapping from a 5 seater to a six seater far easier)
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
