Hello there.  New this this forum. Nice to meet you all.  I just bought a 2017 Yukon XL SLT.  I thought the towing capacity was 8300, but now that I'm reading more it looks like around 6300 without the HD towing package. We're looking at a travel trailer that is 5050 dry weight and 600lbs toung weight.  Seems like the Yukon can handle it even with adding water, but I wonder if it worth trying to add the HD towing package?  Is there an aftermarket way to do it or do I need to go a dealer? Any idea on the upgrade cost?
Edited by awhit22
Nothing you can change or add will change the factory tow rating. It is what it is when the vehicle is built.
Edited by elcamino
Thanks for the response.  Not trying to add addition tow capability, but trying to get to the max capacity of 8300 tow. Everything I'm reading shows the standard tow capacity to be 6300 for the Yukon XL out of the factory, but there is/was a HD towing package option for my model and year that will upgrade a few things to handle additional weight. Larger rear axle, upgraded cooling, different spring on back, (which I think is what silveradosid mentioned above), et . Was just curious to see if that can be added after by the factory or if there is a way to add those after the fact?
Anything can be added but at what cost?
Lager axle means the whole rear assembly will need to be replaced and brakes may not be same either so more cost.
Upgraded cooling means replace radiator and other misc parts
Different springs will also require different shockes
Could cost $5,000+ if having to buy all new GM parts......Be better off looking for another vehicle equipped like you want because you still have a 5.3L engine.
Edited by elcamino
Apologies for the slow response.  Thanks for clarification. Makes sense.
  • 2 months later...
So I am kinda in the same boat.  I am looking to pull a travel trailer around 5700 pounds.  I wanted to upgrade my 2018 Suburban but can't find a way to do it like other manufacturers do.  It may cost $2500-5000 dollars to do it but believe it or not, my depreciation would be more than that to trade for a newer better equipped one for.  Any suggestions o increasing capacity?  I did add an aftermarket Curt brake controller that made a world of a difference.  I have the Premier package on the vehicle, so I like all the bells and whistles of the car.  The axle ratio is the problem at 3.08.  Thank you in advance.
Its cause you have a 3.08 gear that you are limited to 6300. If you dig around on some forums there are lots of guys who tow just over that but complain that they have issues in mountains. Im sure GM put the 6300 tow rating with 3.08 gears for liability reasons and to avoid warranty repairs on rear ends and transmissions. Id do the free trans thermostat pill flip mod if you plan to tow a lot.
  • 1 month later...
I went through this and ended up trading in my perfectly fine and low mileage 2017 Suburban for a 2019 Suburban Premier Plus with the 6.2L and 10-speed. I took a huge hit, but once I priced out trying to do what you are suggesting it wasn't worth it. The other problem is that the vehicle will remain rated for what it came from the factory with. This means if you go through a weigh station and they run your VIN and find you are overloaded you could pay a huge fine and be sidelined from continuing on your way. Heaven forbid if you are in an accident with the trailer and you are over the original tow rating you could be liable for damages and fines, as well. We tow a Winnebago Minnie Plus that is around 6700# loaded and it does fine. The Max Trailering package (which gets you the full tow rating) also gives you an integrated brake controller and trailer sway control that you won't get by adding an aftermarket brake controller. Bite the bullet and get the right truck for your trailer. It is worth it in the long run.
Edited by Miami Son
  • 6 months later...
trans cooler, Max tow radiator, 180 thermostat, activate the PE function and set it to come in around 60% throttle, get the trans tuned for towing, more line pressure,  and synth oil
also get
How can I figure out if the car does have HD towing? I checked several VIN Decoder but they seem to tell always the same tow capacity no matter what Yukon VIN I enter.
My 2017 SLT 4WD does have a Trailer Tow Brake on the left hand side, close to the steering wheel. Is this the ultimage sign of the package? The car doesn't have a VIN sticker and so I'm completely confused about the towing capacity.
Does anyone know how to figure out with 100% confidence?
Thanks
the free online vin decoders typically just have generic info.  you need the actual vin, then go to a dealer or there is a gm email address (don't know it offhand) that you can send the vin to, and they may email back the build sheet for the vehicle.
HD tow package should have RPO number for your vehicles chassis.  A brake controller means nothing. Max HD tow , is based on gear ratio and rear diff size, larger front rotors and caliper, oversized trans cooler, larger radiator.  etc...etc....
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
