C.A.R.B. CAI for L86?
Are you doing it for looks or not. If just for performance gains then the stock box is perfectly fine. Just get a better flowing filter and change the tube.
Sent from my SM-G975U1 using Tapatalk
Thanks gents!  I'm going to have black bear tune my truck and saw that they can get an extra 20-30hp from the volant intake but I'm still under warranty.  I also want to hear the 6.2 but don't want an obnoxious exhaust.
42 minutes ago, flyingfool said:
pull out the air restrictor panel in the oem airbox,
Curious about this and searched but couldn't find anything....can you elaborate?  Thanks.
just get a  rubber or silicone coupler to mate it up with the 6.2 TB, just like the ones provided for the K&N kits.
Alternatively, if you really need to have it be CARB compliant, you can get a Banks CAI. It's 50 state legal and has a CARB EO number.
pull the airbox out, you'll see it
I did just that. It's part of the piece that connects to the fender well right?
yup
if your serious about keeping it cold air, then you can buy some 1-2" foam weather insulation to fill the gap around the fender to box, dont bother with aftermarket air filter ,they're all junk, and you'll never outflow the stock filter without dropping $2000 in speed parts
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,376 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
