Hi I have a 2019 GMC Sierra Elevation with the 8 speed, and was wondering if the 1st to 2nd rough shift is normal for this transmission?  Sometimes it shifts without noticing anything and sometimes it slams into 2nd. Been to dealership like 5 times, last time they updated the program so 2nd to 1st rough shift was fixed but still have intermittent 1st to 2nd. Is this normal or should keep going back?  I test drove an 2020 8 speed RAM and that was smooth like butter. Again thanks for replies .
known issue for cold vehicles. let it warm up first or hold pedal down lightly until in 2nd after initial go.
4 minutes ago, BigredGMC said:
It does it cold or hot. Sometimes worse when feathering the throttle.
Have them change the fluid
Mine only has the harsh 1-2 shift when the transmission is cold and I go straight from reverse to drive. If I give it a few seconds before I shift from reverse to drive I don't get a harsh shift.
This seems to be the general consensus among forum members with the 8L90.
I guess I f it does no damage, if they do nothing I'll live with it. After highway driving I get the rough shift for about a mile or 2.  When cold it shifts smoothly.  Weird transmission.
I had this issue. The thing that consistently worked for me was a deliberate pause after shifting it into gear. Mine only occurred first shift of the day so if yours does it more often it may or may not help. As others have said, the fluid change may be needed.
mine had a rough 1st to 2nd if I rushed it......let it warm up and be smooth especially first drive of the day, after that was pretty much smooth as butter.....right before I sold it I noticed a few more clunky shifts that weren't normal but who knows, could have been mental thing....
Known issue / behavior with the 8-speed.
GM has informed dealers and has explicitly stated they are not to change fluid under their customer satisfaction clause. (GM won't pay for it)
The best advice I can give you is find the transmission guy at the dealer.
He can perform a stationary relearn. if that doesn't work he'll likely have to tear the transmission apart and use a micrometer to make sure the clutches are set properly.
At my local dealer here in Alaska the transmission guy (joined GM in 2000) says that every single one that didn't get better with a stationary relearn he had to tear it apart and he found that the tolerances would not correct in the clutch packs from the factory.
I returned my dream truck over the problem.
Went from a 2019 LTZ tech package to a GMC X31 Elevation. Cost me exactly the same amount of money [emoji35][emoji35][emoji35].
Might want to try to add your name to the class action lawsuit, it's unlikely you'll get much. But it should at least help with the resale value if they win.
Thanks for all the replies. Now for a couple of days while stopped at a red light my engine stumbles and feels like it's about to stall.  It happens about 20 seconds while stopped already.  Does not always do it but has done it twice in 3 days.
It's the stupid transmission tuning. Next time it tries to do it push the brake pedal to the floor. If it stops shuttering it's the transmission tuning.
Do the RPMs drop?
Even on my 10-speed when slowing to a stop and dragging the brake pedal, the transmission is actually fighting the brakes. Every once in awhile it gets so bad that I don't know if I can stop in time. (Feels like it's trying to accelerate)
I just started throwing it into neutral when coming to a stop when it starts behaving badly.
It stops nicely, no shudder only after about 10-20 seconds it feels as thou it's about to stall.  And yes the RPM's drop during that 10-20 seconds.  It never did it before. I'm afraid to take it up north for the long weekend, don't want to be stranded.
How low? And do you have the 2.7 or the 5.3?
    doylej24
    doylej24
  • Who's Online   5 Members, 0 Anonymous, 776 Guests (See full list)
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
