Timbren SES
I'm kinda stuck folks. Trying to remove my factory bump stomps to install some Timbrens in the rear of my truck. I live in road salt country, I've just about rounded off the heads of the 10mm OEM bolts. Tried soaking them in PB Blaster, using a 3/8 sock after the 10 started to slip, and then a set of spline sockets that haven't worked either. Have not tried heat or drilling yet.
So I called the local shop I bought the kit from to swallow my pride and just pay the$130 they quoted me to install in the first place. They tell me it doesn't sound like something they could handle now, talked about the cutting and torches and how it's beyond them. On one hand, i'm glad they didn't just take it back and mess around with something they knew they couldn't fix, but on the other hand, what would they have done if they had rounded the heads off instead of me? They offered to refund my purchase, but in another brilliant move, I cut the bump stop out of the way on the passenger side to see what i was working with, so something has to go on, might as well be the Timbrens.
Maybe one day i'll learn I have many other talents and have little to no business turning wrenches and just pay somebody that knows what theyre doing!
We've all been there man.   This is how you learn.  If you're interested in doing your own work keep trying and you'll feel great when finally figured it out.    If not, just pay someone right from the start.
I remember getting a bolt off a gas tank on an old 95 Isuzu by hammering a open end of a wrench onto the rounded bolt and then smacking the side to turn it but that was super extreme case of needing the tank, having 20 minutes to the part yard closing and then just dumb luck. That entire process is not something I would ever recommend. Just saying anything can be done with almost nothing and once you get what you need done its a learning experience as the first responder said also.
Im curious how the timbrens work out. Good luck man [emoji106]
Sent from my SM-N975U1 using Tapatalk
Take a picture of what you are working with and post it, maybe you can take a cut off wheel and make a notch (think standard screwdriver) and make some progress.
The offending bolt, with bump stop cut away for access. Threads directly into boxed section of frame, with an access hole right next to thread thats only purpose seems to be to collect sand and salt!
Looks like it is out far enough to put a set of Vise Grips on and turn very carefully.
GOT IT!
Been spraying it with PB blaster a couple times a day.  Put a torch to it for maybe a minute or 2. Banged on the head and the bump stop rested a couple times, then pounded on a good old fashioned 6 point 3/8 inch socket, with an adapter to mg 1/2 inch drive breaker bar.  All went smoothly from there. Getting at the other side in the morning!
Brother, you ain't kidding about feeling great now!
In the future too you can also use a grinder to cut a flat into each side. Make it easy to get some adjustable wrench on.
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
