So after seeing both GMC and Chevy doing up to 20% off MSRP for the accessories website I'm considering doing the air intake and cat back exhaust change out. Does anyone feel that there is such a major difference between the Borla S-Type (GM Approved) and the Borla ATAK (non GM Approved) that I should risk voiding the warranty and going with the ATAK? I think either way I'll stick with the GM approved air intake, they look nice and really are cost effective for the most part.
It doesn't "void" a warranty. Exhaust is pretty safe, pretty much the worst that can happen is it rusts out. But it's a borla so that shouldn't be a concern.
Is the ATAK legal for a sound standpoint? I hear ATAKs can be quite loud.
The type s is much less likely to drone.
With all dfm and AFM trucks an aftermarket exhaust is going to make it sound a bit weird while cruising when it changes down to 2 3 4 5 6 7 8 cylinder mode. And particularly weird when it starts skip firing. ( Alternating clyinders per stroke)
Listened to the factory exhaust on here and it sounds good to me.
I saw the 20% off, so I went on line to GM and ordered the CAI, the exhaust and dealer installation -total with tax was $2,200.00.
Just waiting for my appointment with the dealer.
Where did you see that the Borla S-Type was GM approved?  I have one on my truck and hadn't really worried about it but would like to have the reference if it's out there.  Thanks.
If you didn't buy it from GM it's a different SKU.
Not that it matters if the accessory is branded that warranty is independent from GM. There are some exceptions mainly Baja designs lights where GM will assist with warranty resolutions.
As long as it is installed by a GM dealer. Go to the accessories website and it's on there.
That "warranty" is just for the install.
Unless you are talking about the "GM performance cat-back exhaust BY BORLA" if so that's a GM accessory thats covered for 3yrs 36k miles GM warranty.
IDK ultimately it's an exhaust. A pipe for waste gases to flow through. Nothing can really go wrong.
The ones by Borla through GM are warrantied by Borla, not GM.
https://accessories.gmc.com/product/performance/62l-rear-exit-through-the-bumper-exhaust-upgrade-system-with-quad-black-chrome-tips-by-borla-associated-accessories-19419438?year=2020&make=GMC&model=Sierra 1500&modelId=548&body=Crew Cab Pickup&bodyId=22&wheel=Standard Box&wheelId=119&trim=AT4&trimId=5102&drive=4WD&driveId=8&engine=6.2L V8 GAS&engineId=5920&bodyNumDoors=5&categoryId=12009
Quote
Warranty
Non-GM Warranty. Limited Warranty by Borla 1,000,000 miles. For more information contact your dealer.
The GM Performance systems are 3yr/36mi through GM
https://accessories.gmc.com/product/performance/62l-long-wheel-base-cat-back-dual-exit-exhaust-system-upgrade-84527232?year=2020&make=GMC&model=Sierra 1500&modelId=548&body=Crew Cab Pickup&bodyId=22&wheel=Standard Box&wheelId=119&trim=AT4&trimId=5102&drive=4WD&driveId=8&engine=6.2L V8 GAS&engineId=5920&bodyNumDoors=5&categoryId=12009
Edited by newdude
When is your appointment? That's exactly what I am wanting to do but just not sure yet.
Actually waiting for the parts to get in -just called and they didn't get them yet, but said that they will be getting an order in on Monday. Said it is hard for them to check status when the parts are ordered direct?
I'll post something when I get them.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
