On 7/12/2020 at 12:07 PM, Don John said:
My headlighs are always on, how do I turn them off?
Depends on what kind of truck you have Don.  Year, make and model?
  • 3 months later...
I do not like the DLR`s either. Here is a solution for the issue from Gen5DIY. I should of got the cable with the LED turn signal mod as well. Will modify my cable when it warms up again so I can use that feature. Once that was done I changed the 1990`s headlight bulb solution to GTR Lighting Ultra 2.0 LED lights. Best LED solution out the and I have not been flashed by on coming drivers
https://www.gen5diy.com/collections/15-17-canyon-p-p-harnesses/products/15-18-canyon-drl-relocate-stock-led-bulbs
  • 8 months later...
So your saying owners can modify the OEM switch. Show us how without pulling fuses , pulling brake wires, etc and not permanently damaging switch and voiding warranty.
My experience with GMC/Chevy DRL mods will require a relay to make this work. Older "96" vehicle had a rectifier your could pull and then add relay to circuit.
We would love to see instructions on how to do this.
This switch?
ACDelco D1525J Dimmer Switch
You can remove it from the dash. Remove the back of the switch. Remove the spring that returns the knob to auto. Did my 12. Easy.
  • 5 years later...
on my 2000 silverado i could push the domelight over ride on and off twice and it killed the headlight.  oddly enough, there is a little trick for everything.
    Gspleezy
    Gspleezy
  • Who's Online   5 Members, 1 Anonymous, 636 Guests (See full list)
