I have a 2020 3500hd duramax. If I am going down a steep hill in normal mode and I’m not towing, the rpms rev up like they do while in tow mode. The truck slows down and won’t coast like my 2011 gasser. I’m just wondering if this is normal? Thank you
That's the grade brake doing it's thing.
If the exhaust brake is enabled it will assist in this process.
Truck is trying to maintain the speed it thinks you are asking for.
No runaway coasting....
FWIW, max rpm under decel is higher than max rpm when powered
Maximum Powered Speed 3450 rpm
Maximum Braking Speed  4800 rpm
  • 3 months later...
Hello JHarris32.  At your earliest convenience can you PLEASE attach a short video clip of the instrument cluster(rpm guage) while this situation is occurring. Also please note your vehicle's build date, this can be found on the driver's side b-pillar placard. Thank you so much in advance!!
Edited by JRSPerf.
High RPMS?  What are the RPMS at high speeds and flat surface?  Say at 70 and 75 MPH.   MIne runs at about 16/0 at 70 and about 16.5 at 75.  This is of course in 10th gear
I’m curious why you ask. The owners manual for my 2021 gas 3500hd says that transmission grade braking only works in tow haul mode. On mine, grade braking works in normal mode on descents.
Edited by Another JR
My 21 does the same.  If it's a steep enough hill I turn on the trailer mode to make it more aggressive.
Not sure if this is what is going on, but if cruise control is set, it tries to maintain set speed on the downgrades too.
Same thing (downshift/high rpm) can happen with a 1500 gas truck and no trailer -- if the grade is long and steep enough.
With cruise off, it will likely still add grade and/or exhaust braking if you use the brake pedal (which tells it the vehicle is running faster than you want)
HD's, and especially the dmax, are all about load control.
They 'coast' less than a 1/2 ton.
And the 1/2 ton will 'coast' less than the passenger vehicles.
Sounds like the Exhaust Brake is holding your speed. Welcome to a HD truck. If you want to continue to accelerate hit the gas pedal for a bit and I believe it will let you coast, or at least let the truck now you are ok with a gain in speed.
    • What meaningful corrections were done to fix the "machining errors?"   I bet nothing, because the 6.2 is soon to be obsolete. Why would GM implement any fix let alone an "expensive one?"   Until someone can provide any convincing information that GM did ANYTHING to correct the engines - the 6.2 is no for me.    Which means keeping the 2016 Denali longer until the next generation (6.6?) proves itself.
    • If my father took a Sunday off. We did the Sunday drive. Usually stopping at a Geno’s for dinner that we eat in the car. Six of us with my little sister up front. It was always a Buick growing up. In New Jersey you couldn’t get lost. Not like Texas.
    • Hoooooooly smokes, batman!
    • I suppose I am Atlas. It can always be worse, eh?   I had a friend once that rolled one payment into another until he was paying the price of Benz for a 10 year old back marker. Wouldn't be often you start a new payment the month following your old one.
    • I still enjoy the drive   Some people fish when they retire; some golf. I drive. We've lived in the same general area now for twenty eight years and I'm still finding at least monthly some sweet quite little road to explore. When I tell the Mrs. I'm heading out for coffee she knows that could be a five hour event. Often she even goes along.    I like finding new rural routes used mainly by the locals that start nowhere in particular and end the same way. Many in the area of that type are narrow paved and twisty, hilly and run through field and timber. Often along creeks or wetlands. Unfarmable areas of great natural beauty.    After years of this type of exploration they start to fit together. One ending a mile or so from another and you start threading together a new path from a unfamiliar place to a new adventure. Sometimes to a little town of under five hundred that used to be something before the Interstate or some railroad or US highway bled the life out of it that has a small dinner with the greatest slice of pie you've eaten since grandma made her last. A little village museum or library or even a town square park with grand old oak, walnut and Osage orange trees to sit under while you sip you gas station coffee and chat up some locals.    Often they are full of stories about the main streets more interesting buildings and the who's who of the area. Sometimes some hidden attraction or unseen history. Our area is full of old coal mines.     A younger self used to do this going cross country by motorcycle. Only a general area as a destination with no time to get there and no time to be back. Sitting at days end in a 10 unit off the main highway motel under a Sycamore tree yacking with the owner or his one semipermanent guest while I adjusted valves or the chain. Always a wave and a shout "Hey there stranger"!  It's how I came by my love of old Brit iron. There is no such things as a ten minute gas stop when your on a Enfield or a vintage Triumph. Same being true of old cars.    If you take the time to really look I've found everywhere is someplace interesting. Illinois or West Virginia. Different and yet the same.    People are in a more relaxed mood and will talk about anything and everything and if they like you there may be a cupp'a or a lemonade and a sandwich in it. 😉
