Bought my dream truck, turned into a nightmare!
Sorry to hear about the truck.
The owners manual says not to tow before 500 miles and it's recommended to change the oil before towing heavy loads.  Don't know the size of boat you was pulling, plus the weight the load of wood in the bed, but do you think this could of contribute to the engine problem?
  • Replies 40
Totally agree with this. Wanting to complain for faulty issues is fair and I’m with you.. until you flat out don’t follow the vehicle manufacturer recommendations/guidelines for break in and your engine takes a ******.
On 7/27/2020 at 3:19 PM, 1997SierraSLT said:
General Motors doesn't need to manufacture a quality product as long as the consumer continues to purchase.  They are betting on brand loyalty to keep them afloat.  Or at least up until their next multi-billion dollar bailout.
No they are not.  They know you as a consumer are replaceable if you become dissatisfied.  At least for now.  There are other manufacturers though, primarily Honda and Crapota, who realized that they needed to improve their product and reliability if they wanted to have any chance at staying afloat in America, and they did exactly that in the 80s.  Hyundai/Kia realized they had shitty products in the 90s and began bringing on experienced engineers to help improve their product and reliability.  By 2014/2015 they were one of the most successful brands in America, though still not quite as superior as Honda and Crapota.
The break-in recommendation is to ensure a long healthy engine life, emphasis on long because if you don't follow it, it doesn't mean you should expect your engine to take a dump within the first month of ownership. Makes no sense to point a finger at that just to make yourselves feel better about whats in your driveway. It's a sad occurrence that shouldn't have happened but did due to bad luck or poor quality control.
Plenty of well broken in engines have failed prematurely and plenty of those that were abused lived a long healthy life. This goes for all brands, some more than others.
Tons of issues with my 2019 GM ended up repurchasing it. My 2020 3.0L is much better. The 8 speed automatic is a toilet google how many class action law suites GM has pending against them.
Ya dont try and explain that to these people.  this is just a disapoint generation Ive waited for it for a long time really thought it was gonna be much better
This has nothing to do about what's in our driveway.   I asked the OP a simple question which he hasn't got back to answering yet.  He just got the truck and 8 days later loaded up the truck with wood and hooked up a boat, then took off in 100+ degree temps.  The only thing I asked was what was the weight of the boat and payload of the wood (not counting driver, passengers and other gear) and if it could of contribute to the engine problem being such a new truck.  If he would of replied or stated in the OP that the boat/trailer weighed 3k and the payload in the back was 500lbs, it would make sense that it probably was bad luck or poor quality control.  You mean to say that you can tow/haul what every amount of weight you want and don't have to worry about it.
For almost 40 years every 3/4-1 ton truck I bought gas or diesel. Went from the dealer to my gooseneck installer then to my exhaust guy. Then got hooked up to my 7000 lb trailer. Then I loaded up my demo tractor and hit the road. Usually all before it’s first hundred miles. I usually did that every 2-3 years. I lost one engine. It was bad injector seals on a V-10. It led to a lean blown pistons at 40K miles. The results was a warranty replacement. Times that by 4 other of my partners doing the same thing. I test drove them like I stole them. And broke them in the same. I’ve owned mostly performance vehicles did the same. Break in usually was how long it would lay down rubber. Growing up I remember my father usually had the car to beat. Anytime brothers or other family members got a new car. They come out to the country and line up with him. My father was usually driving his latest 455 Buick. That how we broke them in. I don’t think that was his problem.
The nice thing about dreams is that there will always be more.
I didn't quote you in my reply.
And to answer your question, yes you should be able to tow up to the limit right off the lot without your engine crapping out immediately. What do you think these construction companies do with them? They don't baby them for 500 miles then get an oil change before using it for their intended purpose. Those trucks are abused from day one by someone that doesn't own it barely making more than minimum wage.
30k on my 19 6.2L. Has not been to the dealer once since picking it up over a year ago. They keep pestering me to get the recalls done. It's been a great vehicle so far.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   4 Members, 0 Anonymous, 614 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
