Cooled seats barely cool.
On 7/30/2020 at 7:13 PM, Jav_eee said:
Ventilated.
If only the rest of the ram worked as good as the seat coolers haha
No kidding. The ram AC was weak. My truck's AC is fantastic.
Picked up a 2020 CC LTZ in March and traded in an 05 2500 so my only experience with seat coolers is the wife's Hyundai.
Compared to the Hyundai, I would rate the new  Silverado seats at a 4-5.
Anyone know if the Silverado has just the seat or  both seat and back cooling fans?
If it is supposed to have  back cooling, then I would change my rating to a 2.
The A/C is cold enough to hang meat in there. LOL
Fart fans in the seats are barely ok IMO. Yeah, they're nice to have, but I never think about them. Only when the wife is with me and turns her side on. I guess she's used to it driving in her Caddy. I don't care one way or another, but the fans in the Cadillac are stronger than the ones in the truck.
As far as the A/C goes, on a super hot day sitting in a restaurant parking lot, it's very wise to remote start the truck near the end of the meal to get the A/C cooling on. For whatever reason, at first start in high heat, it takes a longer amount of time for the 410A coolant (I think they're using that) to get cold than any other vehicle I've ever owned. Could be a lot of real estate in the ducting to have to cool down, I don't know. But lordy when it gets there it's a meat locker.
Also depends on what vent locations (and fan settings) are being used for the A/C.
As previously posted, effectiveness depends on how cold the air is that is near the intake for the seat ventilator.
Well... the seats are not “cooled”. They are vented. If you’re getting air flow the all is well.
Until the cab gets cool, around the intake, it won’t blow cold air through the seats.
Vented seats are not plumbed into the A/C duct work.
Anyone know if there is a fan(s) on the back also or just in the seat?
I feel something on my lumbar area when I turn it on.
On 7/31/2020 at 9:39 PM, 07HD said:
Here's a thought. My 2020 sierra HD. Works great, and anyone with a skinny a** like mine would be just fine, cant leave it on high for more than a minute. All in good fun.
On 7/31/2020 at 9:40 PM, Jav_eee said:
So what’s the thought?
I think they mean that people of normal BMI don't require constant refrigeration.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,249 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
