I spotted one a few days ago here in Orange County. Wow, sexy!
21 hours ago, Mikedfw said:
No one knows exactly what they will do yet, but should be very similar to the yukon
The only thing we know for sure is the trucks will have the adjustable console out of the SUVs. The actual dash is still up in the air.
I didn't know that part, nice. That's for sure one of the features I'd like on my next Chevy.
I looked at them online......nice..........but,
The price, are you kidding? That's insane with very little for discounts.
No thanks.....
No thanks.....
Yeah, especially when you go over to the German luxury dealer next door and realize that for the same price, you can get a much more luxurious SUV that handles better and has a premium badge. Probably equally (un)reliable but at least they will provide you with a loaner car whenever you take it in for warranty work. You should probably lease either car anyway...
No thanks.....
It really is wild that you can get into a pretty well appointed HC or Denali for the same price as an LT Tahoe. Wow.
If the Suburban held its value as well as the Silverado, I'd consider it. I don't drive much and the way it holds its value is insane compared to all the other cars out there. Even more insane was the $10k discount I got when it was a brand new first-year model. If I could get $10k off the Suburban, I might consider it.. but highly unlikely it would hold its value very well.
I did not need Low Range 4WD on a SUV or to tow 7500 lb trailer loads with it and so I went with the Traverse 2018 that had a lot more cargo space than the Tahoe and averages 22 mpg with city driving and cost $20,000 less than the Tahoe. The ride on the Traverse is a lot better than my Mercedes on the bad roads around where I live.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
