Can anyone tell me why they made the bed to 6’9” and that the hitch does not set right over the rear axle? Does this mean I don’t need a slider hitch?
I bought the long bed and my buddy bought the short bed. I am using a non sliding hitch and my buddy chose a slider. He has been super frustrated that it does not sit right over the axle but could not get help or a straight answer from anyone. First holiday with the truck he slides the hitch and it slid back so far the hitch damaged the tailgate. Long story short at this point I would not recommend a slider hitch unless you absolutely need one. His setup would have been fine without.
The ball is centered over the spring packs for optimal weight distribution.
  • Quote
    • The ball is gooseneck mounting point is 2" behind the axle
    • It is centred on the rear leaf springs between the front hangar and the rear shackle
    • According to GM engineers, supposed to be the right distribution for the standard bed truck, also gives you the additional 3 or so inches to the cab
I came from a Pullrite Superglide in my Dodge Ram to this new truck. After considering all my options, I settled on the Andersen Ultimate hitch. Depending on how it's installed (there are options for positioning), you can get as much as 9" more clearance from the cab. The length of the trailer's pinbox can be an issue with clearance to the tailgate and sides if it's too long.  With mine, I was able to get the full 9" and have a mile of clearance between cab and trailer. And it's a whopping 38lbs which makes it a cinch to get in and out.
too bad when you take the tailgate off you loose all the cameras on the truck and now created a safety issue as well as loosing your fancy high tech system on your 80k-100k truck. guess the engineers must have missed that in thinking nobody takes their tailgates off for slide ins / salt spreaders for winter and whatever else you would need to take the tailgate off.
My 5th wheel trailer is a Grand Designs and came with the turning point hitch. It’s pretty slick! I don’t need a slider because my 5th wheel pin has a giant key in it that keeps the 5th wheel pin from rotating in the hitch itself. Instead it pivots at the pin box where it’s attached to the trailer. I can turn 90 degrees with probably 6” to spare on a short bed truck.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
