2017 injector issues
no12nv
16 days ago truck thru cel ran rough no power shifted hard.. warranty  we go. Bad #8 injector.  300$ later all good last week same ****** even worse. . Took back same ****** bad # 3 , 5 ,6 20% less volume need replace aswell  #8 replace 30% over flow. $1000 later It runs smooth. But if I 2 foot it I rev out at the floor 1200rpm 0 break free burn out jus a dog. Cudnt pull boat up launch no balls even in 4x4. Is it my injectorS again or torque converter.. Truck used ta do a 1/4 mile break stand.. now I gotta have help pulling my 19ft boat up a ramp. Wtf.. I'm lost here.. Truck runs fine on streets but lacks the beast it used to be.. 2017 Silverado  5.3 CIA, borla exhaust.  21000 kms. Any and all input welcomed.. thanks guys..
Run some fuel injector cleaner and carbon cleaner in the thing.
If the cleaner doesn't do the trick, I wrote a how-to on replacing the injectors (assuming you're out of warranty). It drives me nuts when the dealer does all that work just to only replace 1 or 2 injectors. Everything is apart, just swap all injectors the first time instead of doing the job multiple times. If you want to test the TC theory, put the truck on tow/haul mode and it disengages the TC. If you still have the sluggish issue you know it's not that.
Here's the injector how-to:
    Kirk Belch
    Kirk Belch
  • Who's Online   5 Members, 1 Anonymous, 1,300 Guests (See full list)
