Most all of those "bright lights" bother us older folks. Y'all that run them are lucky I'm retired......or we'd be liable to have a visit!?
17 hours ago, reardiff said:
How do you know if your headlights need adjusted?  I just went up to a 33 inch tire and 1.5 level, would this be enough to have to adjust?
I would bet the front end level made quite a difference. i'm sure you should adjust them down.
I bet they need an adjustment that’s why I won’t do any lift or level kit. Level the truck only thing left is a squatting ass. Hit the gas ass drops front points up your lights are always changing direction.
I mean.... you could adjust them and avoid that. It’ll be as if the level was never installed
I don't really have an answer but I'm in MA and my Silverado, my wife's Atlas and my sons' RAV4 and S90 all have OEM LED headlights and I am not aware of any police concerns.
Sent from my SM-G981U using Tapatalk
That’s because OEM setups don’t cause the glare that bothers other drivers.
I see more threads pop up with factory led headlights in LT+  having issues being flashed ?
I have never been flashed with led bulbs in my custom.
Please dont put LED or HID bulbs in a housing not designed for such a bulb. Not only will it produce blinding glare for other drivers, in most cases you will also experience decreased usable light output as the housing will tend to scatter the light instead of properly reflect it in the proper direction.
Edited by OkieMedic
True for HID, but some LEDs, the filament placement is the exact same as a standard halogen bulb, and are perfectly safe to use in a reflector type housing, and with LEDs watt to lumen ratio being better than halogen, they actually do increase your light output.
at one time this was probably true, everything advances with time....
IRT the first part: It doesn't seem to bother other drivers but I could be wrong. As far as decreased usable light output you are definitely wrong, I LOVE the light output of my LED bulbs.
There are specifications for the height of the illuminated area at a given distance on level ground. I used to find a wall and have my truck a distance away and then adjust the lights to get the beam pattern I wanted with the low beam setting.
Forget about lifted trucks, the ones that are "leveled" have the front end raised up and I doubt any of the people doing this are adjusting their headlamps afterwards.
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
