Hello,
What is the difference between the previous generation wheels and the new ones and is it possible to fit the older 22” factory wheels on the new trucks?
Thanks....
Nope. Only a very few will work. Different offset but mainly the angle of the spokes to clear the caliper.
I was just told you would need a 10mm wheel spacer on the front wheels..
Can anybody confirm this?
Thanks in advance
Rich
Edited by Puttnutt24
Anything over 3mm you won't be hub centric anymore unless you get a spacer with new studs. 10mm spacer can't be used with stock studs. What wheel are you trying to fit?
22" Chrome Snowflakes from a 2016 truck...
Part number 20939984
Thank you....
Some snowflakes may fit but close. Post a pic. Why don't you just try it? I wouldn't mess with spacers. If not sell them and get wheels that fit.
I have not bought them yet, I'm just doing my homework..
A new style snowflakes run about $2500 to my house, older ones about $1500..
Here is a photo of the new wheel...
Thank you Sir..
And I agree, I would really prefer to stay away from spacers, I'll fork up the money for the correct wheels instead..Thx
This is incorrect. I personally have some 10mm spacers from BORA and they have the lip for the wheel to sit on. Also you can buy extended thread lugs that will allow you to use the stock  wheel studs.
Just using a 10mm spacer (without lip) won't be hub centric and will be lug centric. Post a pic of your spacer. Your using stock studs with a 10mm spacer? Once you post I'll explain why.
Edited by mafd2
Thank you Sir..
I can get you new offset wheels.
I've got a set of 22" off my High Country if interested.
He can’t resist the chrome flakes lol
As requested. You can see the extended thread lugs take up what's lost from using the spacer. The extended thread goes into the lug wheel pocket so you don't loose any thread engagement.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
