I have a 2011 Sierra SL with a 4.8L.  Battery age is unknown as it was there when I bought the truck.  Over the weekend we were moving our kid into their dorm and I sat out front with hazards on and nothing else.  When I went to leave battery didn't have enough umph to start they truck.  Jumped it and started right up and was fine stopping a couple times on the way home.
I let the truck sit overnight and then checked the battery.  It read 13.3V and then 15.5V after starting the truck.  No problems since.
Was this a fluke or is the battery giving a warning shot before winter?  I will probably just replace the battery before winter, but just wanted to know if I am missing something.
Thanks!
I would go ahead and replace the battery.  However, most any Autozone, O'Reilly's or Advance Auto Parts will test it for free.
Most use a high end conductivity tester to check the battery, and the couple of times I've had one tested while still installed, the battery tester showed that the battery in question was in the final quarter of it's life.  It would have been interesting to have been able to get the battery load tested, but none of the stores I stopped by had one for in car testing.
Being stranded is no fun! Sounds like the battery is on its way out but maybe it will last a bit longer? I highly recommend the duracell platinum agm batteries that can be found at batteries plus bulbs, 48 month free replacement. Excellent performance in all temps. Is it reading 15.5 volts with all accessories on? did you test off the post of battery or both that and alternator? make sure you don’t have a loose ground etc. 15.5 seems high and could be bad cell/failing battery. Before you throw in a new battery make sure your alternator is functioning correctly as to not burn it up!
Edited by 04z71crew
typo
Thanks!
https://www.tahoeyukonforum.com/threads/extending-battery-life.117296/
The Duracell is on my short list for sure.  The 15.5 was with only the radio on.  I thought that seemed a little high.
I think I will listen to chem_man and see if I can get it tested, just to make sure.  Just don't want to go into winter unsure.
Thanks!
It's a board error on the older trucks, most prevalent after a driving rain.I'm on my third battery in 20 years, an A/C Delco from Auto Zone, $89 bucks on my dealer account, they stash them behind the counter. Battery light kept coming on, performed a starting/cranking/charging test, all okay. Hey, we gotta keep 'em going.
Our trucks have a smart charging system, look up RVC (Regulated Voltage Control) and EPM (Electric Power Management), that's why your voltage moves around.  A bi-directional scan tool can look at BCM information, like how the charging system keeps tabs on the battery, State of Charge, Start Up State of Charge, Battery Temperature, etc.
My cheap 30 month battery is now 4 years old and has been in Florida almost all of that time, very rare indeed for this climate.
Very interesting. I was not aware of that. The local GMC stealer is very easy to deal with. I think I’ll stop by and have them hook it up. Thanks for the info. ?
    ncleg
    ncleg
  • Who's Online   5 Members, 0 Anonymous, 781 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
