Goodyear Duratracs or Goodyear All Terrain Adventure.  Which ones do you recommend.  For mostly city and highway drive.  I like the looks for the AT tires.  I just to have All terrain Adventure in my previous truck '14 Sierra was a good tire .  I want to put 275-65-18.
Thanks,
I’ve never had experience with yours, but I have 265/6518s wrangler duratraks on my Sierra. That’s what came stock from the factor. 43k on them and I’ve had zero problems with them.
I did a trip to Duck NC with them and forgot to air down on the beach... still had zero problems. Even in loose sand.
Only thing is I should’ve kept up with rotating them a bit more. Front edges are a bit more worn than the rests at the moment. But like I said, that’s my own fault and I’m sure that’ll be the same on any aggressive corner/edge of a tire
I like my Duratracs but they're notorious for low mileage. I'm all highway  (about 85%) and just rolled 55,000 miles and my tires are N-O-I-S-Y. I don't mind it much because I like the noise and feel of mud tires and now that the treads are wearing down, it starts to have that mud tire feel when at low speeds, high noise at highway speeds, almost like bad wheel bearing noise. My buddy runs Duratracs on his plow trucks and only gets about 45,000 miles out of them. I'm at 55,000 and am going to have to get a new set before the winter rolls around.
I think I'm switching to BFG KO2's this time around. However I have to see how that works with my wheel package insurance. My wheels and tires are covered for 8 years so I have to make sure I follow whatever their guidelines are for tires. If I can't switch brands hopefully I can go a little bigger to like a 275 or 285.
Thanks for your post.  I have some questions:
1.  How is the ride? I have Bilsteins 5100.  These tires are more stiff?
2. Your tires are the original OEM tires
3. How often do you rotate the tires?
4.  The noise is pretty bad.  I have a corsa sport exhaust maybe i can't hear the noise of the tires.
5. any experience driving in the snow with these tires?
Thank you
Edited by Darthmalo
This.  Get Woke, Go Broke.
I can’t tell if you’re trying to bash me or agreeing with me. But either way voting for joe and that hoe is no good. [emoji854]
Thank you
The ride is fine and they handle great in rain, snow, and dry environments.
My tires are not the OEM tires. I had them give me a new set when I bought the truck used with 13,000 miles. Somehow the camber was so bad it put a lot of one side wear on the treads and rotations were not going to fix it. These now have about 42,000 miles on them.
I rotate my tires every oil change so every 6,000-8,000 depending on when I get to the oil change.
I have a Borla ATAK and can hear my tires over the exhaust but my exhaust is pretty quiet when cruising. Really hoping it's not bearing noise I'm hearing.
Snow, these tires work great. I know a lot of plow trucks that run Duratracs but haven't discussed any pros/cons versus other tires with them.
Thanks.  Stock Wheels?  Do you have a picture how they look now?
Worst looking tire. 45400 on them. Purchased the truck with them on it Dec ‘16.
I’m in the same boat and will be getting new tires before winter rolls around.
I do a good mix of highway and town driving. CAI (for what that’s worth) l, 2in level on the front, and I took the air dam off the bottom of it. Still getting 18.1mpg average.
From Long Island to Syracuse I usually get 20.5-22.
Best ride I ever had was an 8 hour ride to my gfs college. 24.1. But that was with no level, CAI, and dam on.
I really do like the looks of the Duratracs. I liken them to the old Goodyear Wrangler TD's that I used to have on my '91 Cheyenne Shortbed 3 speed manual 4x4. Bitchin' truck.
However I doubt I really need duratrac. While I have a little bit of fun off-road at the occasional beach, or camping several times a year, I am usually on paved roads or sometimes on fire roads. My used '14 GMC came with Geolandar HT on it. Great highway tire, excellent fuel mileage.
But I may go with a GY all terrain adventure or a trailrunner when these are worn
Out of your choices I would go with the adventures based on your described use. I would also recommend the Nitto Terra Grappler G2 in P275/65r18 which is what I ended up going with to replace my stock HT tires. Smooth, good traction,  and definitely more aggressive look than stock.
Thank you for all your comments , suggestions and feedback.  I decided to go with the Goodyear All Terrain Adventure size 275 65 18 w/ white letters.  The installation is tomorrow.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
