Got a 2 week old 2021 Yukon Denali. Has anyone else experienced the non-stop "Service Safety Restraint System" alert? This goes off about every 2-3 minutes in mine. Taking to dealership this week, but checking to see if anyone has experienced same issue and if their dealership found a fix.
Just bought 2021 Yukon Denali and after leaving dealership, I am having the same issue with "Check safety restraint system" warning. It is constant. Dealer has vehicle but no fix after two days. Will advise if repaired and how.....hopefully soon!
I have had my Denali 3 weeks.  Same issue.  Took it once, no fix.  Here now, and they said it is a software update that hasn't gotten pushed to them yet.  I've seen on Tahoe forums it was a seat issue with the wiring.  I'm not sure which it is, but thinking I may take it to another dealer if they don't seem to know what it is here.
8 hours ago, Frankdp23 said:
I have had my Denali 3 weeks.  Same issue.  Took it once, no fix.  Here now, and they said it is a software update that hasn't gotten pushed to them yet.  I've seen on Tahoe forums it was a seat issue with the wiring.  I'm not sure which it is, but thinking I may take it to another dealer if they don't seem to know what it is here. There's seemingly been a few different sources of issues. I've also seen one or two that got a software update to fix, another the steering wheel airbag module, and yet the others with the wiring issue in the seat (document number/info is on the tahoe/suburban site that you likely found by now)
Don’t  know of any software update, but there is an updated wiring harness and connector for the driver seat. There is a bulletin for this, I’ll find it later.
#PIT5759F: Service Safety Restraints System With DTC B14DC SYM 1B and/or 13 - (Oct 19, 2020)
Subject:  Service Safety Restraints System With DTC B14DC SYM 1B and/or 13
2021 Denali. Same problem here. Took to dealership about two weeks ago and was told it was a “coil” (I’m a woman and of course fell for this) but a week later mine has started giving me the same alert. Nonstop. I also have an issue with my buttons on back of steering wheel to change stations. Works sometimes. Doesn’t sometimes. When talking on the phone thru the car - sounds like someone is underwater.
you didn't fall for anything. The SIR Coil/Clock spring has been the cause of some of the error messages you are seeing. There's been two sources of the error, thus far. One is the steering wheel SIR Coil/clockspring and/or the steering wheel airbag module. The other source is the inboard driver seat airbag connector. Is the button issue new?
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 686 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
