Vehicles electrical system will not turn off when key is removed and Driver door is shut. You have to go to the passenger rear door open it up and then the trucks electrical system will shut off.
Mine does this....  Its the door module that makes contact with the latch on the driver door.   I have lubricated it and works for a while, then acts up again.   I usually shut-reopen and it all turns off.
I did the same. Sprayed the latch and it worked for a little while. I can’t do the shut reopen thing. Tried just won’t work. Thank you for your response.
Guess we both need to replace the door latch assembly
Sent from my SM-G975U using Tapatalk
