On 6/2/2021 at 11:31 AM, Greg Chevy said:
2020 Silverado RST 3.0L Duramax. Bought in October 2020. 12,500 miles. Rear Main seal blew out, oil everywhere. Seeing this is a common issue and GM has a bulletin out on it. Dealer says 12+ hour repair.
I had two crank seals go within the first 1k miles on my 2020 3.0 Duramax.  First one was supposedly a bad install.  It's at 25k and at the dealer for a glow plug code.  I started shopping for extended warranties but I'm torn on which way to go.  GM or aftermarket my dealer sells.  Or scrap the whole things and get a 22 2.7 gasser.  Looks just as capable as the 3.0.
Edited by texassilverado
3.0 and 6.6 Duramax have 5/100,000 mile powertrain warranty.
Bumper to bumper is still 3/36.
2.8L duramax (colorado/canyon) has the same warranty as the gas trucks
POWERTRAIN COVERAGE
All 2021 GMC vehicles come with a fully transferable, no-deductible, 5-year/60,000-mile Powertrain Limited Warranty. 1500 Series Light-Duty (LD) pickups equipped with a 3.0L Duramax Turbo-Diesel, 2500 and 3500 Series Heavy Duty (HD) pickups equipped with a 6.6L Duramax® Turbo-Diesel Engine, and full-size SUVs equipped with a 3.0L Duramax® Turbo-Diesel I-6 Engine are covered for 5-years/100,000 miles
On 10/9/2020 at 6:31 PM, Wintersun said:
With a auto extended service warranty it pays to shop around and there is nothing to be gained in buying one before the factory warranty expires. With a diesel engine the parts that are not covered by the drivetrain warranty and an injector rebuild alone will cost more than $2,000. Add in the cost to replace the water pump or the EGR or fuel pump and the value of an extended warranty is a no brainer and part of the reason why a diesel will never save its owner money when compared to the total operating cost for the same vehicle with a gas engine.
? parts are not covered? I think you need to check again.
