I HAVE 2020 SILVERADO 1500 RST WITH THE BED LIGHTS. MY QUESTION IS HAS ANYONE ADDED MORE BED LED LIGHTS AND CAN YOU TIE INTO THE WIRING FOR THE TWO BED LIGHTS OR WILL IT THROW A CODE
i have a 2019 Silverado 1500 LD - has bed lights , also added a 36" led strip ( front of bed) splice into bed lights. NO Problem
This weekend I had an interesting issue adding two 60" LED light strips down my step assist bars for entry lighting. I tap'd into bed light on passenger side, worked perfect. However when I went to do the same thing on  driver side the LED strip would just flash. I noticed it was only getting around 10v. I ended up tapping into the reverse wire instead and all seems well. Looks great too imo.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
