So I'm VERY interested in the programmer for my 2020 RST, I was bitterly disappointed to find that they were not available with cooled seats.
If I were to find a set of cooled seats from a higher trim, this programmer will allow for me to control them?
On 10/21/2020 at 11:12 AM, Mjleech said:
I have a Custom Trailboss
is this something I can do on my truck?
is there a way to do the cluster upgrade with this and add in the steering wheel controls to operate the cluster?
is it possible to upgrade the stereo to the 8”?
if any of these are possible, would you guys package any of this together?
Pretty much same question
28 minutes ago, dram1983361 said:
Can this also change tire sizes/gear ratios or is that in the ecm? Would be awesome if so!
From what I've read elsewhere (another product) it would be in the PCM.
Same question
On 10/21/2020 at 9:53 PM, AJ Sullivan said:
So... I snuck an order in under the old webpage (I won't go too much into it because I see that it has changed), and now I see it is different.  I read through all of the directions and instructions... and nothing looks the same now as it did then.  Can you give me an overview of how this is going to work now?  You can email me if you would prefer.  Order #: 17413
So now when you get the rental tool you simply choose the options and configure it on your own its pretty simple :)
On 10/21/2020 at 9:53 PM, flyingfool said:
can you adjust the grill shutters open close vs engine temp with your fancy tool?
No those are ECM controlled.
On 10/22/2020 at 1:44 AM, bamorris2 said:
This is really cool and somewhat closes the gap compared to what ForScan does for the F150’s. Nice work!
Thank you!
Yes the BCM programming will work on the truck. You'd need to email us to discuss the radio upgrade though thats a huge job and want to make sure you understand that first.
Yes as long as they were wired/installed like factory thats no issue at all.
That is in the ECM; thats not our bag ?
On 10/28/2020 at 6:20 PM, 22’s said:
Would this make it so I can turn of my DRL and headlights with the knob? I think I’m reading yes but want to make sure.
Yup! Assuming this is a Canadian spec vehicle; very common request.
Edited by GTPprix
  • 1 month later...
Thank you!
So glad they can modify this!  My service advisor said last week there’s nothing they can do to change this...haha, dealerships.?
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
