Yeah, the Range device kills auto-stop AND DFM. And all you have to do is plug it in... a lot easier than the auto-stop eliminator.
I understand the Auto-Stop is a pain but nothing more than an annoyance than anything and can be disabled by the push of a button. I personally can't see spending $200 to disable it when all I have to do is push a button. Before I installed my Cat-Back I hardly notice it at all. Now that it is installed I only notice it when driving in slow city traffic and/or coming to a stop. The exhaust sounds like the motor actually shuts off then refires when it downshifts into 1st gear. The DFM of course is another matter. I know what the system is there for but wonder what the MPG difference is when it's disabled??
About 1 mpg with 75% highway driving.  About 50 gallons/year in my case.  Hypothetically of course. ?
Comes down to 2 options, and if you want to do a very simple plug and play by your knees (more $$) or the plug n play that goes behind the dash, continues to use the button (less $, but requires some labor)
13 hours ago, GSC52 said:
Anyone here tried the https://www.rangetechnology.com/products/afm-dfm_disabler/ yet?  The stop/start thing really gets on my nerves as well.  I've also heard of people just leaving their truck in tow/haul mode.  My trailboss has the  'race' mode too but I've not tried it enough to see what it does with the autostop.
Lots of people running the range device.  You can perform a search on it and see the threads.  Well worth it in my opinion.
Our Sierra, with just 9K miles, has the Auto Stop no longer working. We don't know why, but I don't miss it! My wife asked if we should take it in, and I said, let's wait!
Edited by C Gerber
Engines run forever if they don't get turned off. Semi trucks achieve 1 million miles all the time. Taxi cabs run well into 750K. Starting an engine is when damage occurs. Do you want to do this 20X a day? Also it takes a toll on the starter, flexplate, battery and relays. I bought the range before I took ownership of my truck. IT WORKS ON THE 3.0!!
I can not find in there literature that the one device does both?
On 11/18/2020 at 12:01 AM, econometrics said:
Thanks gentlemen, this is just what I was looking for! I recently installed a Borla Type S catback exhaust and can really tell when it shuts down 4 cylinders. I have the auto stop off switch, but this is a nice perk to not have to touch that every drive too!
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
