Installed avs vent visors. Anyone have advice for the window pressure sensors reopening? I have to lightly close the windows so the sensor doesn't reopen. Thought I read in the past that these would learn?
If you just installed, you need to give them some time to settle in. I think instructions said to leave the window closed for 72 hrs on mine. I believe it gives the rubber time to mold a bit, and the glue time to set and hold the visor in the right position, so as not to put the pressure on the window that causes it to reverse.
