So I'm probably going to order me a 3500 LT here soon and I'm trying to figure out if paying for the autotrac transfer case is worth it.
Is there any difference between the regular transfer case and autotrac other than 4 Auto? One stronger than the other?
Anyone really use 4 Auto?
I dont know if there is a mechanical or strength difference. I am in the market for a 2020+ GM HD so I'm wondering the same thing. I have the auto4x4 in my 1500 Sierra and I use it all the time. Its really nice if you live in an area where road conditions vary. Colorado high country is a good example.
I've had several 2500 and 3500 GM trucks since 2005.  Personally, I prefer the AutoTrac transfer case.  The 2020 GMC Sierra HD Denali that I currently own has it and it is the first 2500 I've owned that has it.  I have no information if it is more reliable or rugged than the regular four wheel drive transfer case, but I know that I don't like the "bucking" that occurs when turning the steering wheel when in four wheel drive with the old transfer case.
Edited by Thankful
Correct
I would bet strength wise they are equal
the newer versions offering AUTO are nice as stated for general driving in varying conditions with no front tires fighting each other on tight turns with somewhat snowy / less snowy roads, and having the option of full 4WD for constant snow plowing ...
I've had 3 HD's 2004/2011/2015 all with electric shift (all bought new & used by me for over 100,000 miles) and have never had a failure
I believe in AUTO mode the truck is just rear wheel drive and as rear slippage is sensed the fronts smoothly engage as needed - thats how my 2007 Avalanche worked - I liked it
30 years ago I'd say there were issues with the Electric, but now all mine have been flawless
some general info I found
https://tnttransfercase.com/general-motors-transfer-cases/
So I assume the transfer case internals are the same either way, it's just the Autotrac version has the ability to let that clutch pack slip? It's not like the regular version has a solid gear set that engages?
One advantage of Autotrac is not having to worry about forgetting to take the truck out of 4WD.  Leaving the system on won't damage anything whereas leaving 4WD engaged could potentially snap and axle or damage the transfer case itself if driving on a hard, dry surface.  that's an extreme example but it does happen occasionally.
Seems to be some confusion about the different transfer cases.
The older transfer case with the floor shift.
The version with the knob controlled electronic shifter that has been available for a bunch of years now.
The 'autotrac' box, which is new on HD's starting in 2020, although 1500's have had an autotrac box for a number of years.
Autotrac has the additional mode where the truck decides when it should engage the transfer case.
These two have been in use for a number of years:
NQG    Transfer case, with floor-mounted shifter
NQF    Transfer case, electronic shift with rotary dial controls
Starting in 2020 we have modified controls on NFQ, and NQH Autotrac has been added.   NQG Floor shifter gone.
NQF    Transfer case, two-speed, electronic shift with push button controls
NQH       NEW!  Transfer case, two-speed active, electronic Autotrac with push button control
Edited by redwngr
No confusion here. I know the floor shift is gone.
All I'm trying to figure out is if the ONLY difference is the fact the Autotrac has the extra 4A setting along with the electric motor that can allow varying degrees of clutch pack engagement.
I would assume they wouldn't use 2 different transfer cases. One with a solid gear hookup, ans one with clutch pack engagement
50 minutes ago, redwngr said:
They are different transfer cases.
Where are you finding this? Everything I'm finding essentially says the 2 transfer cases are the same, one simply has the capability to vary clutch pressure, therefore accomplishing 4A
https://gm-techlink.com/?p=11710
Welcome addition to the HD models.  I hope Ford and Dodge follow.  The 1/2 ton rams use the same 1500 GM autotrac tcase in some models.  I like the GM offers the autotrac historically even on the LT 1/2 tons vs Ford (late to the game, offer only on lariat+, and still using vacuum hubs?).
Should be reliable, assuming you're not plowing with it in 4auto, but fine for daily driving.
Edited by sabre364
GM has had the Autotrac version on the 1500's for a bunch of years.
It's new to the HDs for 2020.
On current HD's, the LT and SLE are the only trims that can have either box.
Lower only get the NQF, higher only get the NQH
FWIW, the 1500's now have an autotrac box that doesn't have 4Lo as std on lower trims.
NP0    Transfer case, single speed, electronic Autotrac with push button control (4WD models only)
Edited by redwngr
  • 4 years later...
This thread is a few years old, but seems to be on topic for me.  I am looking at 2024/2025 Silvarado 1500 4x4. The 2spd transfer case option is a $200 upgrade. With this selectorI can chose 2 hi, 4hi, and 4lo. Where as the Auto has 4 hi setting and Auto that kicks in as it determines. More like an adaptive AWD, than a true 4wd. If someone could clear this up for me I would appreciate it.
The auto has a clutch pack in it. When it is in auto, it holds at like 10 or 15% until rear wheel slip happens, then it engages. It's worth the money if ordering a truck. Most main roads are plowed and dry-ish and side streets are not in snowy city areas (like Flagstaff or east of the Rockies). Constantly switching in and out *could* be annoying if you live there. If you just visit like me, it's not a big deal. Push a button, done. I would have checked the box if I ordered my truck though.
Both the single speed and two speed transfer cases have the “auto” function as described above. Both have 4 hi, which is a true part time  4 wheel drive with no center differential or slippage function. The two speed transfer case also has 4 wheel drive low, or 4 Lo, which significantly changes the overall drive gear ratio to provide greater torque and speed control while driving on unpaved or slippery surfaces.
To me it makes no sense not to get the two speed transfer case. It’s probably one of the only features that is worth 5 to 10 times what you paid for it at resale because many people will not even consider the truck if it doesn’t have 4 Lo.). It is essential for off roading and for gardening (stump pulling), and really nice to have for steep boat ramps.  Most people not off roading or using steep boat ramps rarely use it, but when you need it, you will be very glad you spent that $200.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
