I have been a lurker using the info from this group to help with by 2015 Sierra, and figured its time to post something.
This is a warning for anyone who wants to add remote start, and maybe other features, to their truck that needs GM to do programming.  If you have a truck that is listed as rebuilt (written off due to damage, but was repaired, verified and put back on the road), GM will no longer do any programming changes.  I recently pickup up the remote start kit from my local GM dealer, installed it and took it in for programming.  The said they can't do it as GM is refusing to make any changes.  After talking to GM, its true.
So, if you want to add anything and you have a rebuilt, 3rd party is your only option.
Now I get the fun of trying to return a part that was already installed.
Hold up you should be able to use this but adding it to onstar might be another thing I'd hope they would add it to their side but using an aftermarket will make adding cell option easier and comes out to the same price or cheaper depending on location and if you can do it yourself. https://www.whiteautoandmedia.com/product/autosync-programmer-scan-tool/
Sent from my Pixel 4 XL using Tapatalk
As mentioned above we can absolutely help you with that and a bunch of other cool stuff with the WAMS Spec BCM :)
On 11/18/2020 at 2:04 PM, Mike Hyde said:
...If you have a truck that is listed as rebuilt (written off due to damage, but was repaired, verified and put back on the road), GM will no longer do any programming changes...
This makes absolutely no sense to me... did GM provide an explanation of their logic to come to this policy?
This is what I managed to track down.  The part the affected me is in the important part near the bottom
GM Techline Information for Branded Title/Warranty Blocked Vehicles
To:                  All General Motors of Canada Dealers
Attention:       Service and Parts Department Personnel
cc:  Dealer Operator
Subject:          GM Techline Information for Branded Title/Warranty Blocked Vehicles
Section 1.5 of the GM Canada Service Policies and Procedures Manual indicates that the New Vehicle Limited Warranty is void on any vehicle with a title that has currently or previously been branded as, but not limited to, salvaged, scrapped (irreparable), rebuilt, junked, totaled (written off) or stolen.  Only transactions for repairs covered by the Emissions Warranty and/or recalls will be processed.  A Warranty Block may be applied to such vehicles and thus Investigate Vehicle History (IVH) must be used to verify warranty coverage.
We would like to clarify that although the GM Techline Customer Support Centre (TCSC) is unable to provide programming or vehicle configuration support on Warranty Blocked vehicles, they will provide support for the following situations:
  • Safety, Non-Compliance and Emissions Recalls
  • Emission Control Systems Warranty
A Warranty Block may also be applied if GM has determined that vehicle modification, damage or misuse has occurred which may impact all or select vehicle components or systems.  Vehicle modifications which may initiate a Warranty Block includes Non-GM (Aftermarket) calibrations.  If aftermarket calibrations are suspected, Service Agents should refer to the procedures outlined in the bulletins below to verify the presence of non-GM calibrations in the vehicle.
#09-06-04-026
#20-NA-090
2005-2006 Chevrolet Corvette with any V8 Gasoline Engine
2007-2020 Passenger Cars and Light Duty Trucks with any V8 Gasoline Engine
2012-2020 Passenger Cars and Light Duty Trucks with any HFV6 Gasoline Engine
2019-2020 Passenger Cars and Light Duty Trucks with 2.0L (RPO LSY) or 2.7L (RPO L3B) Gasoline Engines
2019-2021 Light Duty Trucks with 6.6L Duramax Diesel Engines (RPO L5D, L5P)
#17-NA-100
2017-2019 Light Duty Trucks with 6.6L Duramax Diesel Engines (RPO L5P)
#16-NA-325
2016-2021 Light Duty Trucks with 2.8L Duramax Diesel Engine (RPO LWN)
#14-06-04-003
2014-2016 Light Duty Trucks with 6.6L Duramax Diesel Engines (RPO LGH or LML)
#08-06-04-006
2006-2013 Duramax Diesel Engines (RPO LB7, LBZ, LLY, LML, LMM, or LGH)
IMPORTANT:  Please note that certain GM accessories require a change to the vehicle’s as-built configuration to enable that feature (i.e. Remote Start, Fog Lamps etc.).  Due to the limitation of support permitted for vehicles on Warranty Block, installation of such accessories will not be possible as TCSC are not authorized to alter the vehicle’s “as-built” configuration.  No Exceptions are Permitted.  If in doubt, please confirm eligibility by contacting TCSC prior to the sale and installation of the accessory.
Further information on Voided Warranties and Branded Titles, can be found in Section 1.5 of the GM Canada Service Policies & Procedures Manual.
The Techline Customer Support Centre (TCSC) can be reached at 1-800-828-6860 English or 1-800-503-3222 French.
Cliquez ici pour le français
Document : https://dealer.autopartners.net/portal/cacontent/en-ca/headlines/Pages/GCCA-9-2437.aspx
This message link is only valid through the expiry date.
Expires:Dec 31, 2022 00:00 ET
Thanks for that.  But as I read it, it's due to warranty coverage... so if your truck is outside of the specified warranty limits (time/miles), why would this still apply?
I know I'm preaching to the choir, but dang, this is ridiculous.  They're turning down work for their techs, parts sales for their dealers, and possibly turning away future customers for the brand.
Hopefully it's just a Canadian thing...
They don't want to be liable for anything... There lossing enough money as it is to stupid.things wether it's over site on there side or something they may not of had control of so they see this is helping there bottom line.
I pretty sure this is similar to ford they don't even give them enough understanding of how to change things they give them a text file that says this does this for this series of vehicles.
its fairly common now. mostly came to light with tesla refusing service to rebuilt title cars and even normal cars that are out of warranty they will refuse to work on.
Its BS and its apart of the right to repair act as well. In the end they don't want you fixing what they see as "their" vehicles even though you own it. they would rather you buy another.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
