Of course this happened exactly 1 year after the warranty expired.  I accelerated and then it just lost forward gear like I had put it in neutral.  No forward, reverse, and doesn’t even feel like I’m switching it into Drive or Reverse when it’s running.  Before the warranty went out I had taken it in regarding the delayed cold engagement issue, but the dealership said they could reproduce it of course ?.  So, any suggestions or ideas what could have happened to just lose all forward and reverse gears in this 8-speed?
check for any known TSB's 8 speeds have tech  issues in software and i'm sure a pro shop knows whats up.  call Precision Transmission in TX  he might might know where to point you to. he does quality work but i think he's only into older transmission. 806) 372-2210
also a tuner might be able to reflash it , and do a recal on it and purge cycle. this might work, GM dealer might be able to do this too
Edited by flyingfool
I don’t think a tune or reflash is going to make drive/reverse start working again though, it has to be a physical issue to cause it to go out like that.
3 hours ago, kgkern01 said:
No I didn’t, but I had the dealership do a flush last summer.
Fire it up, put in neutral, and check the fluid level, is it normal?
Since there is no dipstick on the 8-speed, and the fill plug is in the oil pan, I just easily check the fluid.  However I’ve had zero leaks in this truck, and underneath it has no oil at all, very clean, I’d assume it isn’t a low fluid level.  The transmission temp when it went out was not hot either, maybe 190?
Even if you unplugged the wiring harness you would still have reverse and one forward gear as a failsafe. That 8 speed transmission is a huge piece of ****** and has been trouble from the start in 2014. I am the transmission guy at a Buick- GMC dealer and can't believe that GM released this trash and can't come up with any fixes for it. I spend most of my time trying to fix the unfixable, harsh downshifts, flares on up shifts, delayed engagement and of course the TCC shudder.Absolute garbage, they should make a retrofit kit to slip a 4L80 in instead.
If you’re the transmission guy at a GM dealer, any suggestions or ideas as to what could have happened?  I had always gotten a slight whine when I would accelerate hard too, other than the above issue of the delayed cold engagement.  I just want to get an idea of what could have gone out and what I’m looking at for a repair?  Thanks :)
I would be looking for a loss of hydraulic pressure like a pump failure or a catastrophic mechanical failure.Any noises while running in gear and not moving?
No noises, when I put it in gear it does nothing, sounds exactly like neutral.
You of course slid under there and made sure the shift cable and lever are still in one piece and attached I am assuming?
CEL on?
