All,
I can't remember what the final verdict was here.  If I am in "Auto" mode do I lose any MPG benefits?  I usually drive in 2WD mode, but with the roads getting a little worse with the weather, I was wondering if I should just leave it in Auto.
Yes, slightly less mpg with it in auto as the actuator on the front axle stays engaged.
It’s probably not a huge difference but it stands to reason that when in “auto” there is more drag (and wear). The axle shafts and front driveshaft are spinning in auto, everything is engaged and waiting for torque from the transfer case clutch.
.5mpg at best maybe?  As long as it sees no traction loss, only 5% of power will flow to the front end and the diff will be engaged so the rear wheels are still doing 95% of the driving work.
Like others say, wear and tear. I keep mine 2WD unless it's pouring outside.
On a tangent, I leave it in 2WD unless I need 4.  Guess I'm old school but on my older trucks, I'd leave the hubs (manual) unlocked until the moment 2WD failed me.
That said, maybe I'll give "auto" a try this weekend when we're supposed to see some snow
Auto is perfect for light snow/ sloppy roads with mixed snow cover. I rarely even use 4 high.
Auto does allow some brief slip at first and you can still spin a bit, but you’ll never really get stuck unless it’s some nasty stuff.
Auto 4x4 is also my default drag race / gap the car alongside of me at a stoplight mode.
I used to be like that. Then a semi changed lanes and ran me into the median. It was a nightmare getting to the hubs in the deep snow. Once I did I was able to back right out. I left then locked in winter weather after that until trucks with hubs went awry.
Sent from my SM-A505U using Tapatalk
Why not toss in 4 High for that?  Seems like it'd be just a little more slippage and more wear on the clutch.  It's only like 3-4 seconds to swap between.
Eh, I’ve tested 0-60 a bunch in each mode. There’s no appreciable difference in times, get little-to-no wheel spin in either mode. For street fun especially, I just like auto. Can steer without fear, lol.
LOL.. touche
I have made the mistake of forgetting to turn it off and then get the dreaded... "noooo ... I don't wanna turn"
Took it up to GLD for a few bone-stock passes.  Hit a 14 flat but I think a ton of that is due to the speed cap at 98.  FWIW, I also brake torqued a few passes and then just stabbed it.  Stabbing knocked 2 tenths off
Edited by Rob Mugs
And with the clutch slip there is less chance of the front tires bending the tie rods and going full toe in. I know these trucks really don't have the power to do that easily but it can happen. It's common on Duramax powered trucks. Plus when crossing the slick crosswalk lines all the power going to the front end could break something. It's not as heavy duty as it's not intended to be the only one operating.
Sent from my SM-T510 using Tapatalk
LOL.. touche
I was crossing the mountains in Southern Oregon and Northern California a few years ago. It was snowing hard. I was towing my travel trailer with my Duramax. The CHP chain enforcement check point made me chain up the trailer. Not the truck because it's 4WD. Just the trailer. Even though it has BF Goodrich all terrain TAs on it. I was not happy about it. When I stopped to take them off I forgot to take it out of 4WD. I didn't notice it until I got to LA. It was jumping trying to turn backing into the RV spot. As best I can tell it didn't hurt anything. Mostly freeway and it was raining hard the whole time.
Even in auto front diff is still engaged. Will wear parts eventually. Brother in law left his in auto for two years blew out his front diff. Only use when needed.
A lot of cars have full time AWD, so why is it such a wear item on this truck to leave it in Auto (AWD)?
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 373 Guests (See full list)
