I just bought a 2016 Sierra 5.3 and I would like to know what's the best plug and play programmer. I would love one that can adjust throttle response like the pedal commander if they make those. Will be adding intake and exhaust at some point as well
I have a Hypertech Max Energy 2.0 for my 2016 Silverado 5.3 6 spd. It has adjustments for throttle response, shift firmness, shift response, max RPM shift points, rev limiter, speed limiter, and AFM on or off or on only above a selectable speed. It also reads and clears trouble codes and TPMS alarm setting can be changed if you’re running tires that require different pressure than the stock tires. The throttle response and shift response settings made the biggest difference in the drive ability of the truck. I no longer have to stomp on the pedal to get it to accelerate or to get it to downshift.  It also has the ability to adjust for tire size and gear ratio changes.
The shift firmness has 4 different settings and after trying a few different ones, I ended up going with the Tow setting which is one step above stock. With it on the Street or Sport setting, the 2-3 shift around 5,000 Rpm was brutal. The first time it shifted so hard it felt like someone kicked the seat and the traction control light started flashing. Breaking traction around 65mph on dry pavement is a little bit too much for a daily driver. Lol
Edited by HoosierZ
I also added an Airaid Jr air intake with the dry filter. It uses the factory air box.  I added it a few days before the programmer and it seemed to help the throttle response a little bit by itself.
My Diablo Trinity T2 was bad ass. It also served as a gauge. It’s up for sale now if you are interested. I’m boosted now and needed something like HPtuner.
I may be interested if you still have it for sale. Price?
Up to 2014 I used hand held tuners on all my trucks since the were available. There was enough adjustability to feel the difference. Transmission firmness, Rpm, shift points, top end changes, some engine tuning and later eliminating cylinder deactivation. My supercharged trucks came with there’re own tuning. I’m sure custom tuning adds some HP at more cost. I never was let down with handhelds after using pretty much all the brands. The plus was being able to go back to stock with a push of a button.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
