Does anyone know what the function of these are? Are they to help heat up the engine faster and only close while the engine is cold? Are they for aerodynamics and close at highway speeds even when up to operating temps? or both?
I'm asking because (I haven't seen how it's installed yet) but I'm wondering what affect these have on an intercooler. I have to assume it will be in front of the  shutters, but even so if they close it will reduce the airflow "outlet" and might reduce airflow over the intercooler.
From GM
Active Aero Shutters are a General Motors active aerodynamics technology that improve the aerodynamic performance and maximize aerodynamic efficiency of a vehicle in order to deliver better fuel economy.
for the 3.0
The intake manifold houses the integrated intercooler. The intercooler system includes an air cooler/heat exchanger built into the intake, a charge air cooler (CAC) radiator assembled in the front fascia, and an electric coolant pump. The CAC coolant pump provides operational and diagnostic feedback to the ECM. (Fig. 3)
45 minutes ago, elcamino said:
From GM
so definitely may close at higher speeds when a smaller grill opening is still sufficient to keep the engine cool. I may need to ask some qeustions about this.
15 minutes ago, redwngr said:
for the 3.0
I hadn't thought of that, the 3.0 is certainly intercooled also so the factory must have considered that and made sure their solution wouldn't be affected.
In my case its a 6.2, and I'm talking about an aftermarket intercooler.
The 2.7Turbo is intercooled and uses the shutter sysetm.  3.0 diesel does as well but the intercooler is on the top of the engine, but the coolant through it goes to an aux radiator up front.  5.3 with plow prep deletes the shutters for max airflow when a plow is installed.
What you might want to look into is seeing if you can mount a cooler down low.  The 2.7T and 3.0 Diesel use a front lower fascia that is opened up under the license plate bracket for extra air flow.  Both those engine options have a dual shutter system, so the upper main one and a lower aux shutter that controls air flow to the aux radiator for the intercooler.
Description and operation from GM below.  To control these if its possible, you will most likely need to be on a modded ECU from HP Tuners:
Quote
Active Grille Air Shutter Description and Operation
The active grille air shutter system closes shutters in the front grille to enhance vehicle aerodynamics in driving situations where cooling and A/C loads are relatively low and high levels of front end airflow are not required. If high levels of airflow are required the active grille air shutter system will open one or both shutters. The control signal from the engine control module, ignition and ground circuits enable the active grille air shutter actuators to operate. If the conditions for opening the shutters are reached the engine control module commands the active grille air shutter actuators to open one or both shutters.
The dual active grille air shutter system consists of two aero shutter mechanisms located in the front grille for controlling the amount of air flowing through the grille. It includes three wires; ground, power and a Local Interconnect Network (LIN) Bus serial data circuit from the engine control module to the shutter actuator. The engine control module determines shutter state based on various vehicle conditions such as vehicle speed, coolant temperature, fan state, refrigerant system pressure, A/C compressor state and ambient temperature. The engine control module has the ability to command each shutter individually to the open or closed positions through communications on the LIN Bus.
The actuators are powered by an ignition circuit that is active when the key is in the RUN position. The vehicle may have to be driven for up to 13 minutes at speeds greater than 41 km/h (25 mph) before a shutter begins to move. If low ambient temperature is detected, the shutters will remain in the closed position.
Here is a pic of the dual shutter setup.  I red boxed the aux radiator and the lower shutters.
Pic of the fascia:
Edited by newdude
iirc, there is a poster that works for the company that supplies the shutters, and posted that there is nothing that detects that they opened or closed after being commanded to do so --- so for an aftermarket / high performance application it would be possible to trim the slats to suit.
thanks!
I have looked at and considered the alternate lower insert, I think it might be worth replacing. actually doesn't look too difficult to remove, plus my stock one is chrome anyway and the dealer drilled it to install a front plate bracket. I removed the bracket, patched the holes, and plastidipped it, but I sure wouldn't mind just getting a replacement. this might be another motivator.
I will be running an HPTuners ECU
I've seen his posts before, I will keep that in mind. I'd like to keep the functionality of the shutters if I can, as long as it doesn't interfere with intercooler functionality. I still don't know for sure where it mounts, I wonder if it could mount way down at the bottom of the front end where the 2.7L/3.0L lower grill insert with the additional wide opening could provide it with plenty of air.
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
