I'm trying to replace the fluid in the rear differential of my 2003 suburban.  Before I started removing the cover I tried to get the fill plug off first.  Of course it stripped, even after scraping the rust and using lots of PB Blaster.  I eventually got it out, but now I could really use a replacement fill plug.  Does anyone have the part number or know of a plug that will fit?  This seems to be a common problem, but I can't find the part anywhere online.  I guess I could reuse the rounded plug...one last time...
I've seen them on Rockauto before. Any local auto parts store will have them for sure
Cant find it, specifically, on Rock Auto.  Just the drain plug for ones equipped with one, mine isn't.  Unless the drain and fill plugs are the same size, they certainly dont look the same.  The drain plug has the hex head, and the fill plug has the recessed 3/8" socket head
Aaron, not for sure on yours, but on at least the older GM differentials the fill plug was NPT, 3/4" was a common size. You could try and match it up at any hardware store, the recessed plug style may be hard to find, most NPT plugs have a square head.
  • Thanks 1
36 minutes ago, Aaron, not A-A-Ron said:
garagerog, Would I have to worry screwing it in to far?  I wouldn't think so, but making assumptions was worked out so well for me...:)
Shouldn't be a problem, a little anti-seize dope on the threads should make removal the next time much easier.
3 hours ago, Aaron, not A-A-Ron said:
Advance, Auto Zone, and AC delco websites were no help either.
If you're trying to find them through their website, you're probably wasting your time. Go to the store. They should have the in the "HELP" line. I've gotten them there and NAPA before with no issues. Or as mentioned just match it up at the hardware store. Square head isn't a problem
  • Thanks 1
Thanks for the 'HELP' suggestion!  Forgot about that one.  With Covid, going to stores in suburbia can be challenging.  Better grab my mask.
I has been said several times. These are just standard pipe plugs and nothing special.  Any well stocked hardware store should have them.
Finding them at GM parts look-ups can be difficult because won't be listed in a regular parts guide. Fasteners etc are what are referred to as standard parts.  I dare say that AC Delco shown probably fits all from the 1950's up.
Edited by elcamino
They do have a magnet on them I believe.  The fill plug for the rear differential in my 2019 does at the very least (no drain plug as you're supposed to remove the cover.)  The front differential also has a magnet on the drain plug, but not on the fill plug, since the front differential has 2 plugs.
If you want to know for sure, the dealer may be your best bet.  I can't imagine it costs more than $15.
Edited by BlaineBug
For a 1500 Suburban, GM# 444788.  1/2-14 thread, 39/64" long.
For a 2500 Suburban with the 6.0 and 9.5" axle, GM# 93439312.  1/2-14 thread, 39/64" long.
For a 2500 Suburban with the 8.1 and 10.5" axle, GM# 93439312.  1/2-14 thread, 39/64" long.
Quadrasteer fill plug is discontinued, no specs on size/threads provided from GM.
  • Thanks 1
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
