2021 RST with Belltech set at 3/4.5, IHC helpers in the rear. I'm installing a Twisted Metalworkz weld in under bed notch on Friday so it can finally sit at 4/6. Helpers will be added back on so I can tow my boat.
Has anyone else had an issue on a 2021 truck with a bad pinion angle? I installed the Belltech 1041sp kit on my truck and the pinion angle was -10 degrees when it was done. It vibrated so bad I could barely get it to my buddies shop. We modified the rear perches to get the pinion angle close, but still have a vibration under hard acceleration. Once it's sitting at 4/6, I'll check the pinion angle and modify the perches for final to get the pinion angle 0. I called Belltech and since they haven't test fit on a 2021, they can't confirm fitment. Guess I'll be the guinea pig...it doesn't work outta the box lol. c47ad8d985685c9ea6dcce01a209af8f.jpgd247cdbbfb2a711ba8979a585327aad5.jpg2cc9262e3089a50f764a3149f76a4f46.jpg763949cd337589aaa1f1d0f46b463c5a.jpg
Sent from my SM-N970U using Tapatalk
On 1/11/2021 at 8:31 AM, KriptiK said:
IHC 3/5 on 22’s
Tire size? Do you rub in the front? Mind if you can get a picture of how close the front tire is to the inner fender?
I am back forth about 22s and I am glad I finally see a picture (albeit 3/5)
On 1/6/2021 at 8:52 AM, DONS19 said:
Belltech 4/6 drop on 24's. Rides great
Tire size? Do you rub in the front? Mind if you can get a picture of how close the front tire is to the inner fender?  The front wheel, is it centered in the wheel well?
Twisted Metalworkz ......  They have a 4 link coil over I’ve been looking at to do my 4/6 drop.  How are their products?
On 1/11/2021 at 10:18 AM, Jacob Moody said:
So far yes, but I went ahead and ordered the front struts too. The stock front end is way too bouncy. The Belltech shocks are much better than the Maxtracs.
Lmk after installed and running it some miles. I was contemplating doing this as well.
That coilover kit is sweet and I'm sure it rides awesome. I'm hoping my setup will ride good and then hold me over until I can bag this truck. It'll be a good 4-5 yrs for that to happen though.
So far the quality of the notch is very nice, I'll find out on Friday how it fits. Super excited to have this truck finally ride good and not bottom out on every bump in the road. It was lowered when it had 375 miles on it, so it's basically rode like ****** for the whole time I've had it.
How many miles do you have on your truck?  I’m of the mindset of do it all at once then enjoy the ride.
1100 miles...just got it this past Thanksgiving. After I ordered the notch and it took 3 weeks to get here. It showed up just after I went back to work...after having 10 days for the holidays. I was trying to get it done over my break, just didn't work out that way.
If I had to do it all over again I might've used the Twisted Metalworkz front and rear coilover with 4 link. It's more than twice the price of the Belltech kit but it comes double adjustable vikings. I would have to assume it rides bad ass.
I might find out for you. Just sent the shop that is going to work on my truck their kit info.
285/45r22.  No rubbing.  If going with 24's it's recommended to go with 295/35.  My roads are bad so I didn't want to chance it on 24's with the lower profile tires.  Sorry, I don't have pictures but I'll try get some this weekend.
On 1/12/2021 at 7:48 AM, 808 HI said:
IHC 3/5 on 24" dubs, planning to do a 4/6.
CA6EB9B5-D58B-44FC-9DE8-80CB6FAA376F.thumb.jpeg.3aaff623d45ae8380f25549888aa88a8.jpg.01fc55dd86cd091b392953e044e0ac53.jpg
Nice!  You on Oahu?  Who did your install?  Or did you do it yourself?
I appreciate the info!
Yup, on Oahu. Rads did the install and alignment.
Put the notch in today and it's finally sitting at 4/6...so excited! Rides great, no bottoming out. Still need to modify the perches to correct the pinion angle, it's worse now since I put the lowering shackles in. Don't understand for the life of me what GM changed on this truck from the 2020's. Shouldn't have to modify the belltech kit to fix the pinion angle. Is what it is now, no turning back!
Still need to decide on a wheel but leaning towards a 24x10 Vossen HF6-3. Future mod will be C6 ZR1 calipers to match the blue center caps lole61a962f9eb0b6823d46dd91591a934e.jpg5d88ffe71aef835b1b130350d29b8813.jpg15abaf3de34cf7e3c71dfda3a93cb7a3.jpga1816af5fdfe50978e89cb066fa25910.jpg17595b348e40d1f119981125b311cdb2.jpg425add02177fae0d33255dc3372aa4b3.jpgbd49bf92b645803155c0e57c5bda79cb.jpgb8fca36e51db418aca15ae59b6ed1e60.jpgf8171228de3cebc4a7f3b642954ec4b2.jpg
    LCH14
    LCH14
  • Who's Online   5 Members, 0 Anonymous, 758 Guests (See full list)
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
    • Your truck lowered, looks good. I'm happy with the stance on this. I may need the extra ground clearance given my location/situation.
