2021 RST with Belltech set at 3/4.5, IHC helpers in the rear. I'm installing a Twisted Metalworkz weld in under bed notch on Friday so it can finally sit at 4/6. Helpers will be added back on so I can tow my boat.
Has anyone else had an issue on a 2021 truck with a bad pinion angle? I installed the Belltech 1041sp kit on my truck and the pinion angle was -10 degrees when it was done. It vibrated so bad I could barely get it to my buddies shop. We modified the rear perches to get the pinion angle close, but still have a vibration under hard acceleration. Once it's sitting at 4/6, I'll check the pinion angle and modify the perches for final to get the pinion angle 0. I called Belltech and since they haven't test fit on a 2021, they can't confirm fitment. Guess I'll be the guinea pig...it doesn't work outta the box lol. c47ad8d985685c9ea6dcce01a209af8f.jpgd247cdbbfb2a711ba8979a585327aad5.jpg2cc9262e3089a50f764a3149f76a4f46.jpg763949cd337589aaa1f1d0f46b463c5a.jpg
Sent from my SM-N970U using Tapatalk
On 1/11/2021 at 8:31 AM, KriptiK said:
IHC 3/5 on 22’s
Tire size? Do you rub in the front? Mind if you can get a picture of how close the front tire is to the inner fender?
I am back forth about 22s and I am glad I finally see a picture (albeit 3/5)
On 1/6/2021 at 8:52 AM, DONS19 said:
Belltech 4/6 drop on 24's. Rides great
Tire size? Do you rub in the front? Mind if you can get a picture of how close the front tire is to the inner fender?  The front wheel, is it centered in the wheel well?
Twisted Metalworkz ......  They have a 4 link coil over I’ve been looking at to do my 4/6 drop.  How are their products?
On 1/11/2021 at 10:18 AM, Jacob Moody said:
So far yes, but I went ahead and ordered the front struts too. The stock front end is way too bouncy. The Belltech shocks are much better than the Maxtracs.
Lmk after installed and running it some miles. I was contemplating doing this as well.
That coilover kit is sweet and I'm sure it rides awesome. I'm hoping my setup will ride good and then hold me over until I can bag this truck. It'll be a good 4-5 yrs for that to happen though.
So far the quality of the notch is very nice, I'll find out on Friday how it fits. Super excited to have this truck finally ride good and not bottom out on every bump in the road. It was lowered when it had 375 miles on it, so it's basically rode like ****** for the whole time I've had it.
How many miles do you have on your truck?  I’m of the mindset of do it all at once then enjoy the ride.
1100 miles...just got it this past Thanksgiving. After I ordered the notch and it took 3 weeks to get here. It showed up just after I went back to work...after having 10 days for the holidays. I was trying to get it done over my break, just didn't work out that way.
If I had to do it all over again I might've used the Twisted Metalworkz front and rear coilover with 4 link. It's more than twice the price of the Belltech kit but it comes double adjustable vikings. I would have to assume it rides bad ass.
I might find out for you. Just sent the shop that is going to work on my truck their kit info.
285/45r22.  No rubbing.  If going with 24's it's recommended to go with 295/35.  My roads are bad so I didn't want to chance it on 24's with the lower profile tires.  Sorry, I don't have pictures but I'll try get some this weekend.
On 1/12/2021 at 7:48 AM, 808 HI said:
IHC 3/5 on 24" dubs, planning to do a 4/6.
CA6EB9B5-D58B-44FC-9DE8-80CB6FAA376F.thumb.jpeg.3aaff623d45ae8380f25549888aa88a8.jpg.01fc55dd86cd091b392953e044e0ac53.jpg
Nice!  You on Oahu?  Who did your install?  Or did you do it yourself?
I appreciate the info!
Yup, on Oahu. Rads did the install and alignment.
Put the notch in today and it's finally sitting at 4/6...so excited! Rides great, no bottoming out. Still need to modify the perches to correct the pinion angle, it's worse now since I put the lowering shackles in. Don't understand for the life of me what GM changed on this truck from the 2020's. Shouldn't have to modify the belltech kit to fix the pinion angle. Is what it is now, no turning back!
Still need to decide on a wheel but leaning towards a 24x10 Vossen HF6-3. Future mod will be C6 ZR1 calipers to match the blue center caps lole61a962f9eb0b6823d46dd91591a934e.jpg5d88ffe71aef835b1b130350d29b8813.jpg15abaf3de34cf7e3c71dfda3a93cb7a3.jpga1816af5fdfe50978e89cb066fa25910.jpg17595b348e40d1f119981125b311cdb2.jpg425add02177fae0d33255dc3372aa4b3.jpgbd49bf92b645803155c0e57c5bda79cb.jpgb8fca36e51db418aca15ae59b6ed1e60.jpgf8171228de3cebc4a7f3b642954ec4b2.jpg
    • Can anyone explain why the oil pressure runs higher after the DFM is shut off?  just installed the Pulsar Lt.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
