Highcountry88 Posted February 2, 2021 Posted February 2, 2021 Whats up everyone! Just joined, excited to be a part of this. My question today is about wheel spacers. I'd like to add a slightly aggresive stance to my 2014 silverado high country. So I have a 2.5 inch leveling lift im putting on and I would like to get some wheel spacers. I was thinking 1 Inch. If I get 1 inch to do I need to upgrade or modify anything else? I'm willing to spend the money if needed, i just want to do it right. If anyone has any insight it would be greatly appreciated. Signing out, Highcountry88
slumpychuck Posted February 2, 2021 Posted February 2, 2021 No need to modify anything else but if you are going to go as much as 1” I would recommend BORA style spacers that actually provide new wheel studs versus disc style spacers that just take up thread space on your existing. Link below to MS Tech who sells the spacers I mentioned. Goodluck to ya!https://www.motorsport-tech.com/special/truck/chevy_sSent from my iPhone using Tapatalk
dcarl Posted February 2, 2021 Posted February 2, 2021 I’ve got a set of used 1” BORA spacers I’d sell for $100 plus shipping. (All hardware included)
Highcountry88 Posted February 19, 2021 Author Posted February 19, 2021 im interested in the 1 inch wheel spacers how can i check to make sure they will fit my vehicle? and how can i be sure i wont get ripped off haha im very new to this forum.
slumpychuck Posted February 19, 2021 Posted February 19, 2021 $100 is a great deal. Just ask him what they came off of but I imagine 1500 GM 6 lug, standard pattern. Sent from my iPhone using Tapatalk
YukonXL04 Posted February 19, 2021 Posted February 19, 2021 On 2/1/2021 at 8:42 PM, Highcountry88 said: Whats up everyone! Just joined, excited to be a part of this. My question today is about wheel spacers. I'd like to add a slightly aggresive stance to my 2014 silverado high country. So I have a 2.5 inch leveling lift im putting on and I would like to get some wheel spacers. I was thinking 1 Inch. If I get 1 inch to do I need to upgrade or modify anything else? I'm willing to spend the money if needed, i just want to do it right. If anyone has any insight it would be greatly appreciated. Signing out, Highcountry88 I believe at 1" there is a really good chance you will have to trim your stock wheel studs some. I did 1.5" and the stock studs still protrude a little into the back of the wheel. But my stock 20s have a recess and I didn't have to trim the studs at all.
It's Tim Posted February 19, 2021 Posted February 19, 2021 On 2/1/2021 at 9:42 PM, Highcountry88 said: If I get 1 inch to do I need to upgrade or modify anything else? I'm willing to spend the money if needed, i just want to do it right. If you plan to change the suspension like that make sure you budget for hub bearings which will not last very long. 1
slumpychuck Posted February 19, 2021 Posted February 19, 2021 If you plan to change the suspension like that make sure you budget for hub bearings which will not last very long.New wheel bearing because of 1” spacers? Can you expand on this? Sent from my iPhone using Tapatalk
slumpychuck Posted February 19, 2021 Posted February 19, 2021 I believe at 1" there is a really good chance you will have to trim your stock wheel studs some. I did 1.5" and the stock studs still protrude a little into the back of the wheel. But my stock 20s have a recess and I didn't have to trim the studs at all.Ah, you are absolutely correct. I forgot I had wanted to go 1.5” but was not willing to trim the studs. Ended up going 1.75” instead. The guys at MS Tech are really great and they’ll make some custom for you if you want to get precise. I think the actual protrusion on the studs is something like 1.65” so you could shorten them by .15” if you really wanted or just get the off-the-shelf 1.75”s. Sent from my iPhone using Tapatalk
dieselfan1 Posted February 19, 2021 Posted February 19, 2021 New wheel bearing because of 1” spacers? Can you expand on this? Sent from my iPhone using TapatalkTim never has anything helpful.Only the doom and gloom.Sent from my Pixel 3 using Tapatalk
YukonXL04 Posted February 23, 2021 Posted February 23, 2021 On 2/19/2021 at 11:28 AM, slumpychuck said: Ah, you are absolutely correct. I forgot I had wanted to go 1.5” but was not willing to trim the studs. Ended up going 1.75” instead. The guys at MS Tech are really great and they’ll make some custom for you if you want to get precise. I think the actual protrusion on the studs is something like 1.65” so you could shorten them by .15” if you really wanted or just get the off-the-shelf 1.75”s. Sent from my iPhone using Tapatalk I guess your wheels didn't have a recess in the back? I didn't trim mine at all with 1.5
MikeBMW Posted February 23, 2021 Posted February 23, 2021 My guy at the tire dealership recommended strongly against putting on wheel spacers. I figure, like Farmer's insurance, he's seen a thing or two.
slumpychuck Posted February 23, 2021 Posted February 23, 2021 I guess your wheels didn't have a recess in the back? I didn't trim mine at all with 1.5I guess not but sure enough to those bastards were just past the tip on 1.5’sSent from my iPhone using Tapatalk
Register a new accountSign in
