I must have gotten a rotten egg!!????. I can barely crack over 20 mpgs with this truck. I average around 18.
How are you guys getting these mpgs???
1 hour ago, OnTheReel said:
Mine in a 5.3L after 2 years and 14K miles is about the same... 16mpg.
Too much idling / remote starts for me. And my “commute” is 2 miles on a stoplight, 30-45mph stretch of suburb road.
I wish the computer would not include idling when the truck is in Park. My wife’s Honda doesn’t.
I must have gotten a rotten egg!![emoji23][emoji23][emoji23][emoji23]. I can barely crack over 20 mpgs with this truck. I average around 18.
Cruise control. It helps alleviate the right foot problem.
I took a look tonight, and I'm going to make some of you cry. I have the 6.2.
25 mile best = 33.1
50 mile best = 23.9
400 mile best = 20.9
Nice try. I set it. How do you think my 2018 averaged 24 mpgs consistently?!?   Nothing drives me crazier than people who drive on the interstate or open highways and don’t set it. Ugh!
My truck ? just doesn’t get it.
Also the only difference from my 2018 to 2019 is:
GMC vs Chevy——-new front end is a lot bigger!
8 spd vs 10 spd
bed length 5.8ft to 6.6 ft
same:
6.2L engine—-realize one was AFM vs DFM
CAI S&B
catback exhaust
crewcabs
22inch wheels
running boards
mud flaps
tonneau cover
just crazy to me my average is about 4 mpgs less. When DFM is supposed to be better.  But like I’ve said the 10 spd had more than made up for it in my mind. Would just be nice to see an improvement since others are seeing it
how about the fuel??  I always run premium 91 in it here in Midwest. It’s highest grade we have.
I’ve been running 88 E15 through the last few tanks. Cold and snowy, not doing any towing or “spirited” driving. Most gets wasted in remote starts and drive-thrus so I got tired of spending more. I think mileage is worse with the 88 but the conditions haven’t helped.
Summer I run only 93 and still get crap. Hope I don’t have to feed this thing at $4+/gal in the future...lines would have to be drawn.
I’m with you on price of fuel. As you know I’m swapping out motors in my boat and I just have this terrible feeling that gas is going to skyrocket over $4 with this new administration to push for more EV sales.  Which makes
no sense because according to the media and Washington the economy is hurting. So why push up gas prices???  Stupid. Instead of people putting $60 to $100 in their vehicles filling them up. People could fill up for half that price and put the other money back into the economy. STUPIDITY at its FINEST we have there folks. No reason gas should ever go above $2
When I first got my truck i was able to run 93. Now that I've moved to California I'm stuck with 91, and it is already at $4/gallon. I could fill up at the gas station on base, but I don't know if it's Top Tier fuel. I go to Arco because they only have a $0.35 service charge for using cards at the pump instead of $0.10 more per gallon, and Arco is cheaper by about $0.40-$0.50/gallon. Another name for Arco is AM PM. If love to use Chevron and Shell, but the same quality gas for ~$10 more per full up just isn't worth it. I'm even questioning if Top Tier fuel is worth it for our trucks since we have direct injection instead of the previous setup where fuel was sprayed and then had to pass the valve to be detonated.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
