Who cares how fast it is in the 1/4 mile.
Horsepower and torque numbers don't mean diddly if it can't be used . When it comes to putting the power to the ground the Duramax is the King. So puff out your chest and smile.
This reminds me of the Polaris ,Arctic Cat and Skidoo horsepower wars .
AC and Skidoo always have had more horsepower engine for engine . The Polaris was always 10&15 hp less but would kick ass on the others. The reason. Clutching. The engineers up in Roseau figured out how to make less ponies do more.
The folks that engineer the Dmax/Allison do the same thing.
Here's a sentence from the article that should give you a woody.....
The Chevy's shifts are more assertive than the Ford's, and the rev-happy diesel never comes off boil as it makes forward progress. [emoji123]
Here you go Dmax fans ...
[emoji122][emoji122][emoji122][emoji122][emoji122]
Yahoo! Voices: Tested: 2020 Chevrolet, Ford, and Ram HD Pickup Pull-Off.
https://autos.yahoo.com/tested-2020-chevrolet-ford-ram-130000953.html
BTW did I mention that this whole electric truck bs is annoying [emoji35]
Long live the deeezle.
Sent from my Pixel 3 using Tapatalk
i mean i guess it’s good to be top dog, but realistically any of these three engines is far more than adequate for almost any realistic use of a 3/4 ton truck.  for me personally, i do not think 25 hp or ft lb either way would influence my decision on what truck to buy.  I would be thinking more in terms of long-term reliability than getting the truck with the most possible pulling power.
The awesome duramax wins the pulling game, but it's in the ugliest looking body of the three.
I mean that's cool and all, but I don't use my truck in such a niche category.
At this point when they're set up correctly none of them are actually going to out perform the other in any way that truly matters, EXCEPT it seems when it comes to exhaust braking.
I'm not sure what GM or Ford did but everything I now read says their exhaust braking sucks compared to Ram.
Yes, the Duramax is awesome but its the 10spd that makes this version so great.  Regardless of what you think of the looks (I think it looks awesome by the way) it is a MUCH better combo with the 10spd vs the 6spd.
Hmm interesting.. Good point about the 10 speed.  I wonder how the 2019 L5P would do with the 6-speed.
I agree!!
Plus its a damn good looking truck!!!!
How different would the results be if they had used 3500 trucks instead ... bringing the Ram HO Cummins and Aisin into play?
For the record, I think the exhaust brake works just fine on my truck when towing my 5th wheel. I just had to get used to how to set it with brake taps. That said, it would be nice if it was more effective in around-own, unloaded driving. My old 2004.5 Ram 3500 with PacBrake worked great in that regard and saved on brakes.
Edited by Njmurvin
The results from the ford would be the same. They can't spool up so they are in third place already. The dodge would obviously do better with more ponies.
Bottom line the Chevy put the power to the ground . The other two lose too much power in the drivetrain. The Chevy also keeps the revs at max the whole run.
I'm huge into truck pulling and this was a cool test. Not like them nimrods on TFL truck.
I don't really care how well mine pulls a competition sled or how it pulls 30k up the Ike (TFL test).
All I care about is how well it pulls my 12k lb 5th wheel up (and down) the long 6 percent grades that I climb going to the Eastern Sierras. I will be testing that in June. I have made a couple of trips with shorter 6 percent (and more) climbs and it performed beautifully (especially on the way down - once I figured out how to best use the e-brake).
Edited by Njmurvin
It will do juuuuuuuuuuuuust fine for those little hills.
That's exactly what I expect. My 04.5 Dodge Ram 3500 would struggle a bit with that climb. It was bone stock with a 4 speed 48RE and 3.73 gears. My CTS2 monitor alarm for EGTs was set at 1400 degrees and even the stock truck had no problem exceeding that whenever I buried my foot in it on that long climb. So, I would have to back it off from time to time to keep the EGTs in line - for peace of mind. It made for a tense 15-20 minutes on the long Sherwin Grade.
My hope is that I can set the cruise on my new truck to 60-65, sit back and let the extra hp, torque and that 10 speed do their work.
Those Dodge's would have been great with a 5-speed auto.
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,309 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
