Just got Trail Boss on Monday, so not alot of driving time so far.
Initial impressions: Trail Boss drives much better than ZR2. Interior on Trail Boss much nicer and much more room than ZR2. Seats in Trail Boss are much more comfortable than ZR2.
Gas mileage of trail boss so far has about 1 mpg better than ZR2.
Both trucks look good on exterior. ZR2 does have locking rear and front diff, which is helpful for extreme off-roading.
Trail boss has power sliding rear window, ZR2 has manual sliding window which was a pain while driving.
One disappointment on Trail Boss is the lack of auto-dimming mirror, I am already looking into adding one. I found connector inside of overhead console. Just for a truck that listed over 59k, it should have auto-dimming mirror. For me that is a necessity. Thanks to this forum for giving advice on adding one.
10 speed Transmission huge difference over 8 speed transmission.
I’d like to learn about adding the auto-dimming mirror as well. Can you link any threads you’ve found already.
Did your truck come with 20” or 18” rims? My 6.2 has 18” and they had a 5.3 that had 20”.
Mine has the 18" wheels. I prefer the 18".   As for the auto dimming mirror, I have one ordered. I have everything prepared and ready for mirror.  Very easy to do, remove overhead console (4screws).  Find the connector / plug that is not plugged in. It will be glued to roof area.
Plug in the new mirror and install. Plastic cover around mirror has to removed to install mirror.
Autodimming mirror is a Gentex. Paid 55 dollars for it. GM sells the mirror also, about 110 dollars. Gentex has button to turn auto dimming on/off. GM has no button.
On 2/20/2021 at 11:18 AM, TNTSilverado said:
Actually it does say right on the paperwork that you signed when you bought the truck. It breaks down what the cost of the Trailboss and your trade in for the ZR2.
Beautiful color and truck too
Would not be a fair price to share since trade was negotiated in deal. I did get 4250 rebate and 1000 GM card bonus.
Edited by steig
FWIW, they are all Gentex and just get rebranded.  They're like the Luxottica of dimming mirros
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
