Curious if anyone has the 3.0 in their AT4 with 35” tires to see what their fuel mileage is. I currently have the 6.2 with 35x11.50 Ridge Grapplers and would like to know what the 3.0 would yield with the same setup.
I want a 3.0 as well... but mpg seems weak to me... my 5.3 does close to what 3.0 does.. and fuel is cheaper... my 5.3 has a range so it is not the mpg best configuration for it either..
What's your hand calculated mileage?
I'm getting about 650-700 miles per tank with my 3.0.
Getting around 30mpg Aran average speed is 60 mph, best I’ve seen is 40.3 mpg at speeds of 45 mph for about 15 miles.
Is your RST a 2wd or 4wd. and tow mirrors or standard?
4wd with standard mirrors.
I have hand tested two tanks - one was a half mpg low and one a quarter mpg high than the dash. I am no hot rod... but i think you need more than 25 mile distances to get a fair reading. 50 mile distance should always be lower... stock tires with 42 lbs in them. 6 sp.. bedcover, which helped mine a liitle too. Nobody should gripe about either motor. They are both great. I suppose if i wanted the next step up in mpg i would need a canyon with the duramax....
All that said... i do think that the 5.3 is doing 2 mpg better than my F150 with 2.7 did. The 2018 sierra is a little shorter than the ford... and maybe that is what we are measuring. Anyway.. this L83 is so much superior to my ‘05 yukon 5.3 i can’t believe it. Astounding.
Edited by PPK
I think whole tank distance or at least the 450 mile setting is the only reasonable long term mileage. If I do my once a 3 month trip on the I highway for 25 miles, my 50 mile average is amazing (about 23-24mpg). Otherwise, my 450 mile average is 16.2mpg, which is far more realistic to the hand calculation over a tank of 95% city driving.
Agreed. My since new mpg is 23.8 at 11,000 + miles. I am always on the open road - no city.  That is 1 mpg better than my f150 - and it read 2 mpg high on the dash... Ferds!! That 2.7 Ferd is good motor, too if you don’t mind new oil pans every couple oil changes...
Edited by PPK
Nope, you'd be surprised on how much better the 3.0 in the Silverado gets than the 2.8 in the Colorado. See the EPA comparison below on the 2 trucks.
Here are my best scores for each of the truck's computer as well as my current tank of fuel. Obviously the 25 and 50 mile range are very inaccurate. I wish they had options of 100, 250, and 500 since the 3.0 has the capability of going well beyond 500 miles on a single tank.
Yeah, Im gonna call BS on the comparison....
I own both trucks.  My Denali maxed 36mpg on a road trip.  My Canyon made it to 46mpg.
Either way terrific numbers, but no way better than the Canyon diesel.
Those are the EPA posted numbers that you'd find on a window sticker. Real world numbers are always different. Obviously even different for every person according to the mpg numbers posted throughout this forum.
Oh well... when a canyon starts looking as good as this sierra.. i will trade. It will be a while..
    DM22
    DM22
  • Who's Online   6 Members, 1 Anonymous, 1,658 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
