Yes. The dealership replaced the tailgate dampener and both switches. Not to jinx it but the tailgate seems fine. It took about a month for the parts to come in.
Have your dealership contact Central GMC in Norwood Ma and ask for Bill in service for more info....
My turn.... bought a year old 2020 AT4 last month. went to help a friend tow a boat home Friday and when we arrived after 45 minute drive the tailgate was down and an expensive marine battery was no where to be found! No chime or warning! I bought it to tow a camper with... I cannot have it come down while towing or it will contact the camper tongue jack ! Guess it’s going back to dealer!!!
Took my in on Tuesday, dealer disabled the switch at the tailgate and ordered a new one (waiting part).  The random opening and shutting in park has stop.  Until I get the new tailgate switch, I can only open/shut with dash switch or key fob.
So I'm having this issue now.
For me it's the main tailgate. First it started doing it after I had pressed the button. Clicking/unlocking over and over. Eventually would stop but every time I accessed the main gate by pushing the button it would start again.
Truck is going in for it's first oil change Friday. They are going to fix it then hopefully. I'm really surprised that this tailgate came out in 2019 and we're still experiencing this. Very frustrating.
Dealer replaced the switch in the tailgate and that fixed the issue with mine. Took about three weeks for the dealer to receive the new switch.
Thanks guys. I called ahead hoping they can get the order in.
Also, I couldn't take it anymore and disabled the switch. Hasn't happened again since I disconnected it. For me, it was the yellow wire pictured. You need to slide the red tab back in order to depress and unplug the switch.
Update: Dealer "fixed" the issue a couple weeks ago. Tech stated they repaired a loose connection. Well the thing started opening again the other day. It's back in the shop today (all day). They didn't finish diagnosis today because they performed an intellilink update and replaced my nicked steering wheel cover - that took 8 hours apparently. I will tell them to contact Central GMC in Norwood for the tailgate issue in the morning.
What is a reasonable compensation for warranty issues like this? This will be day three without my truck for this issue and they "don't have any loaners available"... If it weren't for COVID I would be screwed right now with getting to work.
That stinks, I had to wait about a  month for parts and it took them a half day to repair the issue. Have talk with Bill in Service.
I would have them disconnect the tailgate buttons while they order new switches. Your tailgate will still work via FOB and inside the cab switch (minus inner tailgate) without fearing it opening whenever.... It's been since early April since my repairs and fingers crossed... Two switches and dampener...
Friend of mine had a 2020 Sierra. His tailgate would randomly drop. Caused some damage when it dropped while towing a trailer. He had it to the dealer several times, they couldn't duplicate and refused to fix the damage. He got so frustrated he now drives a Ram. Talked to him a few days ago. He's much happier.
Yea I disconnected it myself when it started happening so that it wouldn't damage itself. That's why i posted those pics above for anyone else having the issue.
Bill isn't with Prime anymore. I spoke with the new service manager last time but I'll talk to him again about making this right. That's the most frustrating thing about this all... just make it right. Customer service is so dead (at least in MA). The dealership thinks that because this is a warranty issue that they don't have an obligation to make the customer happy. The free service is sufficient... well that's BS. $60k dollars later and no vehicle for 3 days... that inconvenience should be compensated.
    C. Hart
    C. Hart
  • Who's Online   2 Members, 1 Anonymous, 622 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
