I've decided the tow mirrors, while really great for visibility and function, are just overkill for my needs.  I'm trailering less and I'd rather go with the standard size.  Currently I've got the tow mirrors with all the bells and whistles, power fold, 360 view, blind spot, lane assist, task lamps  etc and want to get standard mirrors with all of the same features.
I believe the right part numbers for a 2020 would be these below, looking for a second opinion before I pull the trigger.  any inputs are welcome - thanks
84898874
84898875
Edited by romclean1
pgamboa
The Harness Doctor may be able to help.
He's the MAN for K2's.
Might be working the diagrams for the T1's by now.
:dunno:
Click on his name link above to find him.
Edited by Grumpy Bear
10 minutes ago, Grumpy Bear said:
Your welcome. 😉
I pinged Phil, he doesn't have anything for those yet, something he's going to look into someday.  I'll call the local part guys and find out if those are indeed the right mirrors and see what the wiring looks like when they arrive.  Thanks for the suggestion tho, I've used his mirror tap product, great quality.
Or even trading, where are you located ? I have black mirror caps power heated with lane assist non power folding  RPO code DLF  RPO code for the caps is DP6
I'd be open to a trade, but I'm looking for the full featured mirrors. would have have to lane assist, power folding, 360 camera, task lights etc
I've got the mirrors you are looking for with black caps.  Camera's, blind spot, power folding, lights.  I'm looking for the factory installed tow mirrors with all those functions.  i'm willing to trade mine for those if you still have them.
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
