I bought a 2009 gmc Sierra with a 5.3 vortex engine with 51000 original miles on it. It has a tapping noise at start up.quiets down after engine warms.Is this normal or do I need to have it looked at?
It's probably one of the hydraulic lifters on one of the AFM cylinders ticking against the cam assembly. Very common problem. Could also be a small leak on your exhaust manifold which seals up after the engine warms up.
Sent from my SM-G892U using Tapatalk
Piston slap is always very common to the LS engine. Once the engine warms up, the pistons expand and the noise slowly goes away.
4 hours ago, Robert Joye said:
So should I worry about it ?
no. I know many people who have this issue and are pushing near 300k.  If you keep up with your truck, and keep an eye on things like Oil pressure, temp etc you should also get many miles out of your motor.
Get a bi-directional scan tool on it and check for misfires and can also function test the  AFM system.  Do the easy stuff first, check the plugs, compression test, check for exhaust leaks, get a mechanic's stethoscope and listen around to pinpoint the noise, etc.  You can even use a screwdriver or extension stuck to your ear and whatever you want to listen to.
Can you isolate which cylinder? If it's an AFM cylinder I'd consider getting a programmer or a range kit to deactivate it before the lifter collapses.
    • 2026 3500HD.  Mostly empty. Grocery getter. What tire pressure are you running for 37x12.50x20. I have 37x12.50R20 Toyo Open  Country RT pro and been running around 55 lbs front and rear and it's too much. Tires are wearing more in the middle. Toyo says 45 front and 50 rear. Chalk test and it's still too much. I lowered it to 40 front 44 rear see what happens.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
