Service ESC after 6000miles??
Hey all I bought a 2020 Chevy Silverado RST brand new from the dealer in December. I put about 6,000 miles on it already (traveling) and now I got a rattle every time I accelerate, check engine light flashing, service brake light, service ESC light. Like wtf? Did I just buy a lemon? Anyone experience anything like this?
I plan on taking it to the dealer but are saying they don’t have loaner trucks for me even though I have a travel trailer I need to tow
rattle and flashing check engine light sounds like a misfire condition.  If you're using consistent top tier gas I wouldn't think that was the problem...  Hopefully your build date doesn't put you in the valve spring TSB.  Good luck.
Call GM Customer care and tell them you need to get it repaired but must have a  compatible  vehicle . be nice but  firm and  they will ok the dealer to rent you something from enterprise . its how it works for us .
I had similar warning lights and had to replace ignition coil.
The lights might all be related to a sensor or connection serving the ESC.
Might not take long to check/swap.
I've seen the service esc light come on a couple times in two years so it can also be a fluke and nothing to worry about. But not when coupled with an actual problem. My 2019 is my personal reigning champion of weird non-issues.
"No, I did not leave the radio on the last time I used the truck!" lol
Edited by Minnvmax
On older trucks I've had the ESC (stabilitrac) fault occur when there was a bad wheel bearing causing change in sensor gap, or a wiring issue near a wheel.
    Frank V
    Frank V
  • Who's Online   7 Members, 0 Anonymous, 1,242 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
